Hi all good co-travellers in audio-space.
Mixing a song in PT and monitoring the mix on monitors and headphones. Bouncing the mix offline and 1. import the bounce to the mix session. It sounds as the mix 2. copy the bounce to google drive. Streams from there and listen on 2.1 macbook air M1 speakers - totally different and very WET. 2.2 mobile phone speaker - totally different and very WET 2.3 headphones connected to macbook - almost as mix 2.4. headphones connected to mobile phone - almost as mix Something about mixing I'm not getting here, or is there some side-image boost, or reverb, on the macbook air, or.. what is happening it sounds awful Please un-confuse me. any tip/advice welcome. /T
Free beer tomorrow !! - but until then - we're stuck in the present moment |
You always have to be careful about
1. What exact software are you playing back through and does it add EQ or other effects. This also applies to any monitor controller the Pro Tools monitors are using. Phones and their media players may especially perform processing on the audio. 2. Are comparisons done at the same SPL on similar monitors/phones or are you just hearing those differences? To start with compare using the exact same headphones... they need to be easy to drive for phones/portable devices. You have huge differences here, I am not sure why you expect a phone or laptop speakers to not sound very different from professional monitors or (hopefully) good headphones or earbuds. If you are targeting that playback you may need to remix for them. 3. What exact source are you bouncing in Pro Tools? You have to be super careful that you have a bounce source selected so you are bouncing exactly what you are monitoring. This is a common mistake. -- And be careful say if you bounce out things with say final bus/master fader processing on them and then reimporting the bounce and have that track set up with final processing reapplied twice, likewise if you bounce at a point before that final processing when you reimport the bounced track make sure it still is going through the final processing. |
So: it always sounds "kinda right" when using headphones but bad when using speakers?
Most likely you have heavy phase cancellations going on. When using headphones you don't notice them because you listen to L/R isolated. Use a correlation (phase) meter on your stereo bus and see what's going on there. Heavy usage of stereo width enhances could for example be a problem... |
^^ this.
There is nothing wider than full left to full right. Plugins which claim to "enhance" stereo width are messing with phase. Try to mix a song with all channels panned to either full left, dead center, or full right. Holy Trinity of panning positions. That will teach you important lesson.
Hi Daryll. thx for chiming in here
Thanks for you comments, but I cant find anything reallly. I hypothesize that the small speakers of the mac m1 with its trebly sound, along with possible mac-intrinsic widening/bass processing reveals some ****ty stuff I have done in the mix. If so, what to look for? Or is transfering an audio file through google drive from PC to mac altering audio? well it shouldn't. /T
![]() Quote:
Headphones - got it. thx. Quote:
I have som instances of YUM Spread light in haas mode of operation, in the mix. Used as widening, and sometimes as panning. I'll remove and see what happens. ...well hear, not see...
![]() Quote:
guess I'll have to do that.
![]() Quote:
Just moving digital audio files elsewhere does not change them. You have a pile of highly feasible causes in front of you, you don't need to invoke witchcraft. Apple Music player sure does processing. Sound "enhancer", EQ, sound check, ... You need to check all that crap is turned off. Then if you are using Airpods or similar yet more crap can happen with sound transparency, isolation, spacial stereo processing. Disable all that crap. Then get some common playback set of easy to drive (so you can best drive them from an iPhone etc. directly) headphones or earbuds and get really used to them. Playing back on your Pro Tools systems, Mac, iPhone, whatever... and use that as a part of this testing. If that playback sounds wrong in comparing stuff then work out what is happening. Then once that is OK you can listen to computer or iPhone speakers etc. I have several pair of Etymotic IEMs that are revealing and I know very well, I'll use them for comparing playback on devices.. they are not what typical users are likely to be actually listening with, that's a different test, but they can help hear what is going on. If you are targeting playback on small crappy speakers etc. You might want to put a small crappy speaker/device on the Pro Tools system directly as a fast way of doing tests. |
Offline Bounce vs Realtime Bounce vs Recorded-in-Session - BIG differences in PT2021 | andresix | Pro Tools | 13 | 11-19-2021 07:03 PM |
PT12 on Windows 7 Pro- no multiple bounce source tracks in Bounce To Disk window? | js_nyc | Pro Tools 12 | 6 | 04-21-2016 03:37 PM |
Bounce to Disk issues and bounce to direct show error. | SeattleHank | Windows | 7 | 01-01-2014 12:41 PM |
Reverberant VO | Jeremy Lock | Post - Surround - Video | 8 | 07-12-2006 10:40 AM |
5.1 wont bounce. Says "bounce handler cant keep up try convert after bounce...." | Trash Man | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 9 | 05-21-2001 08:28 PM |
