Go Back   Avid Pro Audio Community > General Discussion & Off Topic > Training
Old 03-13-2025, 03:12 AM
VijayP VijayP is offline
Default Toggling instrument tracks using MIDI keyboard
Hi !
In a studio set up, I can directly access my laptop and toggle between different instrument tracks. But during live performance; is there a way to assign specific keys / controls on my MIDI keyboard so that I can toggle between tracks ? I am struggling to find out how this can be done so please advice or guide me to the right resources online. Thank you very much !
Old 03-13-2025, 06:13 AM
tope d's Avatar
tope d tope d is offline
Default Re: Toggling instrument tracks using MIDI keyboard
On a Midi Keyboard, Not sure, it may depend on your midi controller. If on your keyboard, shortcut would be control + P or ;
to switch to different tracks
-Tope
To create a support case with Avid Support, go to https://www.avid.com/learn-and-suppo...-music-support
www.topedomingo.com
Old 03-13-2025, 05:22 PM
Thank you Tope ! Yes I use those shortcuts on laptop. I saw in some videos that for some other DAWs, MIDI keys (for example the leftmost note on the keyboard) can be assigned to toggle between tracks. Which I think is very cool. So wanted to check whether this is possible in pro tools.
Old 03-13-2025, 06:08 PM
massivekerry's Avatar
massivekerry massivekerry is offline
It is not built-in to Pro Tools. You could use Keyboard Maestro to program a MIDI note to trigger a Macro, which could be assigned to the Key Command needed. It'd take some programming.
Honestly, the easiest thing (assuming you're using a Mac) might be to use MainStage. $30. Then you should be able to easily assign MIDI messages (including notes) to patch changes and track switching, once you get used to it. You can even pick up a cheap MIDI Bluetooth footswitch (like the MVave Chocolate or HotShot) and keep your hands free.
Kerry Smith
http://apothekerry.com
Pro Tools since '94.
Mac Studio M1 Ultra : 128GB RAM : Sequoia 15.4 : Carbon : PT Ultimate 2024.10.1 : S1 : Metagrid Pro
Old 03-14-2025, 09:50 PM
Thank you Kerry ! Had not thought about solution outside pro tools. I use windows but I found some alternatives to Mainstage which work in windows so I will try them.
My Midi Instrument Plug in is playing the wrong notes compared to my MIDI KEYBOARD ElCarletto Pro Tools 2 11-28-2022 12:56 PM
Can one midi or instrument track, trigger, multiple instrument tracks simultaneously? jamesleonard Pro Tools 2019 5 05-24-2019 07:33 AM
Unable to resize mini-keyboard to the same on instrument & midi tracks foxes macOS 4 07-07-2013 01:20 PM
2 instrument tracks each controlled by different MIDI input/instrument Midimax Pro Tools M-Powered (Win) 0 03-20-2012 03:10 PM
iI there a keyboard shortcut for toggling preroll? bryanbassett 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 11-08-2005 05:27 AM
