Go Back   Avid Pro Audio Community > Pro Tools Hardware > Pro Tools | Carbon
Old 02-20-2025, 10:01 AM
LFO LFO is offline
Default Mac don't see Carbon at all
Hi.Installing a new MacbookPro M4 (I know it's nor supported yet but trying to test as many users do).Using the sonnet adapter plugged directly on the MBP,
Mac don't see the Carbon, in network the sonnet is there but no Carbon. Changed cable, restarted dozens of time, nothing.. Carbon still show up on my intel iMac as usual. Anybody have an idea . Thanks
Old 02-20-2025, 11:49 AM
tope d's Avatar
tope d tope d is offline
Default Re: Mac don't see Carbon at all
Sorry, M4 is not yet supported, might be the issue
-Tope
To create a support case with Avid Support, go to https://www.avid.com/learn-and-suppo...-music-support
www.topedomingo.com
Old 02-20-2025, 11:59 AM
creativecontrol's Avatar
Indeed, I haven't tried an M4 machine yet with Carbon.... However, does the Carbon device show up in the Show Network Device Browser of Audio MIDI Setup? Is the Carbon device showing LED activity on the network port and in the System Settings > Network?
best,
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Old 02-20-2025, 12:05 PM
LFO LFO is offline
best,
Jeff
No Carbon doesn’t show up in network and audio midi setup and no led activity on Carbon as well. Very strange as I know some people run Carbon on those new M 4 Mac
Old 02-20-2025, 12:07 PM
LFO LFO is offline
Yes as I said first I know it’s not supported but as some users run Ptools Carbon on M 4 , was just seeking for advice.
Old 02-20-2025, 12:09 PM
Copy. Just to verify, if you plug any other network device into the Sonnet you get network connectivity in System Settings, yes?
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Old 02-21-2025, 01:45 AM
LFO LFO is offline
Jeff
Thanks for responding.Yes the Sonnet works OK with other devices. I don't get the led net on the Carbon so it really looks like it's not connected at all.That's weird, even if there are compatibility problems, it should see it in Network....and again Carbon still show up on my intel iMac (running Monterey)
Old 02-25-2025, 12:20 PM
K Roche's Avatar
K Roche K Roche is offline
Humm yes weird ? have tried the second AVB ethernet port on the Carbon
Yes should show in up Audio Midi SET Up as well.
Does it show in Mac System Settings >Sound ?
Also Have you tried powering the entire system and computer off... Then powering on Carbon, then power on Mac, then toggle mac Wifi on and off then Launch PT (That is currently the only way I get Carbon to show in Playback Engine on OS 15.2 and PT 2024.10.2 on my studio system
System :
Studio - Avid Carbon interface , PT Studio 2024.10.2 Mid 2020 (intel) iMac 27" OS Sequoia 15.4
Mobile - 2021 14 " MBP M1 Pro PT Studio 2024.10 --Sequoia 15.1
Enjoy the Journey
.... Kev...
Old 02-26-2025, 02:20 AM
LFO LFO is offline
Thanks for responding.Yes I tried to power on Carbon first, second, Wifi on/off etc Anyway it's not about seing Carbon in AudioMidi or Protools as to begin with Carbon is not seen in Mac system Ethernet devices and of course the Net led don't light on Carbon, so it's really Mac don't see Carbon at all.Checked cable, reset Carbon firmware...no luck. I think it's a Sequoia problem with the Sonnet adapter which is plugged directly in Mac or maybe a M4 compatibility thing.I did a command terminal Sonnet gave me and now I can see Carbon in the ATDECC window but the address appears greyed....will let you know..thanks
File Type: jpg Capture d’écran 2025-02-24 à 13.45.15.jpg (27.1 KB, 0 views)
Old 02-26-2025, 08:47 AM
dominicperry dominicperry is online now
Is the light flashing on the Ethernet port of the carbon (IIRC there's a green and a yellow for each port, on the back)? If not, cable or adapter problem.
Do you have another adapter to try (Apple double-dongle arrangement)?
The cable is still the most likely failure point.
Dominic
MacBookPro M1Max 16" 10/32 64GB 2TB, Sequoia 15.2, Pro Tools 2024.10.2, Carbon.
D-Control/Command Remote Control of Carbon or Carbon-Pre Mic Gain bigbuddy3 Pro Tools | Carbon 2 01-15-2025 05:50 AM
Pro Tools | Carbon & Carbon Pre compatibility with AVID S4 Control Surface [email protected] Pro Tools | Carbon 9 09-14-2023 10:36 AM
To Carbon or Not to Carbon... That Is The Question... Sparky1 Pro Tools 47 04-20-2023 03:32 PM
use Carbon and Carbon Pre together as one interface in Logic/Cubase ? pm mastering studio Pro Tools | Carbon 0 12-22-2022 01:54 AM
