Old 04-10-2024, 12:10 AM
ajazzie ajazzie is offline
Default Sonoma and Ethernet/ v Control and Control 24
Can anyone please help me with the problem I have with V control/ Ethernet being recognised by Mac Sonama
I just bought a studio M2 and the Ethernet won’t see the control 24.
I had I working well with windows but I’ve come back to Mac for a few reasons not to go into.
Protools can see the v control software , it’s just the Ethernet tab in v control setup won’t see the Control 24.
The network settings won’t see an Ethernet port connected either, I can create on but it stays non active.
I’m out of ideas, any help greatly appreciated.
A Gentleman is one who can play the bagpipes, yet chooses not to.
Old 04-10-2024, 05:08 AM
DetroitT's Avatar
DetroitT DetroitT is offline
Default Re: Sonoma and Ethernet/ v Control and Control 24
Could it be 10gb speed?
Apple thunderbolt to 1gb adaptor maybe?
Just passing thoughts.
Old 04-12-2024, 11:53 AM
Gemylon's Avatar
Gemylon Gemylon is offline
Or you could try ...
https://neyrinck.com/help/resetting-...o-preferences/
MacBook Pro M2 Max / Pro Tools 2024.10 / MetricHalo ULN-8 MKIV / AVID Console C|24 / UA 6176 / Neumann U67 / Oram S200 / UAD Octos /
Old 04-13-2024, 10:48 PM
Thanks all
Apple checked this machine, no issues.
I bought a USB to Ethernet, solved.
Not sure why but at least it’s working.
Old 04-14-2024, 08:44 AM
This is not a surprise, and something discussed on DUC in the past.
As suggested by DetroitT above, the 10 Gbit Ethernet in the Mac is not backwards compatible with the ancient steam powered Ethernet (10Base-T aka 10 Mbit) in the Control 24. Just because devices have RJ45 connectors does not mean they are compatible.
Old 03-26-2025, 03:52 AM
mumble72 mumble72 is offline
Originally Posted by ajazzie View Post
Thanks all
Hello I have got the same problem. Can I ask if you managed to solve with a USB 3 t Ethernet or form USBC to Ethernet? Thanks
Old 03-26-2025, 03:54 AM
Hello so which could be the solution? Thanks
Old 03-26-2025, 07:36 AM
smurfyou smurfyou is offline
Any Mac compatible USB-C to Ethernet should do it.
~Will
Old 03-26-2025, 09:34 AM
I've got a Mac studio with Sonoma, the Digidesign control 24 is plugged via ethernet port but most of the times is offline
Old 03-26-2025, 09:35 AM
I will try an USBC to RJ45
Control 24 w/ USB->Ethernet adapter? The Chinese Pro Tools TDM Systems (Mac) 3 04-23-2009 11:55 AM
Control 24 Ethernet Switch MusoPro Post - Surround - Video 4 08-30-2007 02:02 AM
Ethernet Control option WaDa TanK 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 02-17-2005 09:55 AM
Control 24 and Ethernet cachemira ICON & C|24 2 05-29-2003 06:59 AM
control 24 and ethernet connection ianmiller ICON & C|24 3 03-02-2002 11:24 AM
