Old 11-18-2024, 04:40 PM
creativecontrol's Avatar
Default Re: Pro Tools wants to install helper software on every start
I believe this issue is related to the Shoe Tool. See here please:
https://avidtech.my.salesforce-sites...er-tool-prompt
best,
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Old 02-09-2025, 08:49 AM
Rader Ranch Rader Ranch is offline
M4Pro mini OS15.2 PT Ultimate - the method described in the Avid link does not work for me. Someone else mentioned getting an error on the 2nd Terminal command but it still working, not the case for me (Load failed: 5: Input/output error
Try running `launchctl bootstrap` as root for richer errors.)
Have there been any updates to the methodology to get rid of this prompt on every launch? It's still the shoetool...TIA
Old 03-26-2025, 10:17 AM
Guy McDude Guy McDude is offline
perhaps its user error....
But I get as far as the password request.
But im unable to get terminal to accept my password.
any idea what I might be missing?
Best,
Sean
Sean McDonald
Red Medicine Recording LLC
Sofa King Music Services
http://www.seanmcdonald.com
Old 03-26-2025, 10:44 AM
What exactly errors etc. do you see on the screen?
This is likely just the sudo command asking for your normal macOS account password.
What happens if you try some innocuous command with sudo. Like
$ sudo date
Get that to work first.
Old 03-28-2025, 01:09 AM
$ sudo date
Hi Darryl,
Sorry I wasnt more clear.
I was referring to this Avid fix posted above.
The fix was in the Terminal App.
I was able to follow the script/ fix until I was prompted for my Apple user PW,
and the terminal would not accept/ recognize my typing of my password.
I also tried copying and pasting the PW as the previous entries were copied from the Avid script.
so...I was never able to complete the linked Avid remedy, as for some reason I could not input my PW, a necessary part of the linked fix/ script.
Best,
Sean
Sean McDonald
  #16
Old 03-28-2025, 12:31 PM
merlin.audio merlin.audio is offline
Please note that the terminal doesn't show you typing the password for safety reasons. Just type it in and hit enter. Also keep in mind that you need to enter the password of your macOS account (what you enter when signing into your Mac), not your Avid account password or anything
Lastly if you go to System Settings > Login Items > Allow in Background, please make sure that "Pro Tools" is allowed to run in the background.
  #17
Old 03-28-2025, 12:41 PM
Hi Darryl,
I know what you were trying to do. Read what I wrote carefully, I suggested you just try the benign "sudo date" command as a test. What exactly happens when you do that?
Either you are doing something wrong, or your system has sudo permissions increased (normally any user account on macOS with administrator privileges can run sudo but it's possible to still restrict sudo use. So what *exactly* do you seen happening on the screen?
  #18
Old 03-29-2025, 08:07 PM
thanks, this is a good note, I wasnt aware.
It is, and this is the strange part of all of this.
No auto updates, no manual updates, no system changes.
just a few days ago it started asking for the helper file
Best,
Sean
Sean McDonald
  #19
Old 03-30-2025, 02:26 AM
Can you uninstall Pro Tools using FreeMacSoft's AppCleaner?
Note that AppCleaner uninstalls ALL Pro Tools-related files so ALL OF YOUR PREFERENCES, including keyboard shortcuts, presets, and so on, will be DELETED
It gives you the list of files it's targeted before it deletes them, so you can back everything up.
Then reinstall Pro Tools. That will give you a completely clean install like on day one.
If this is not an option for you, I'm afraid the best option you have is to ask Avid support about it
FYI this may be a file permission issue so if you can figure out where the helper installs its stuff, maybe you can find out where the problem lies
  #20
Old 03-30-2025, 11:02 AM
best,
Jeff
Hi Jeff,
Not sure if you know or not, but following your linked fix/ script.
after step 6 "launch Pro Tools", it once again, asks me to "instal helper tools".
there is no mention in the script about this pop up, and whether or not I should allow it to install the helper tool, before moving to step 7, all the terminal stuff.
thanks in advance
Best,
Sean
Sean McDonald
Error - Pro Tools Needs to install Helper Tool jrollins macOS 6 04-22-2024 08:51 PM
"Pro Tools Trying to Install Helper Tool?" anackman Pro Tools 12 8 03-23-2016 04:31 PM
Pro Tools is trying to install a new helper tool - Every time it's run gregsmith macOS 4 11-21-2014 11:22 AM
Have to install pace extension software each time I start Macosx before PT9 will load belolab Pro Tools TDM Systems (Mac) 11 07-27-2011 05:23 PM
