Old 10-20-2006, 09:18 AM
Meanclown Meanclown is offline
Default deltafw.sys causes Page Fault Blue Screen Error
deltafw.sys is the firewire driver for ProjectMix I/O - I am constantly plagued by the blue screen of death telling me there is a page fault in non paged area caused by deltafw.sys - I'm running XP Home - 1 GB RAM Dual Core, (2) 160 GB harddrives, I minimized/eliminated all non-essentials as per www.windowsxp.net - the only thing I haven't tried ('cause Dell in not cooperating, and M-Audio is not helping much either) is going into BIOS to disable caching & shadowing as the recurring error message suggests. Anyone ever have a similar scenario? Do I need to even run page file in my virtual memory, or should I try setting that to "off" completely (currently set to the recommended custom setting of 1.5 to 2X RAM)? Headed for my 19th nervous breakdown here...thanks in advance..
Old 12-28-2006, 05:29 AM
Marcus S.'s Avatar
Marcus S. Marcus S. is offline
Default Re: deltafw.sys causes Page Fault Blue Screen Erro
Hi
I also am having the same problem.
Blue screen with deltafw.sys message
Any solution?
Old 12-28-2006, 11:20 AM
The Mastermind The Mastermind is offline
Hello,
What drivers are you guys using??? what chipset FW card are you guys using???
Old 01-01-2007, 03:39 PM
Marcus S.'s Avatar
I'm using Via VT6306 chipset (advantek networks)
Firewire Driver Version: 5.10.00.5036v2
Old 01-01-2007, 08:18 PM
mikenielsen mikenielsen is offline
Meanclown, I was wondering if you have found any solution. I am running a Dell 360 workstation and have had the same blue screen pop up lately, since I just updated my Project Mix firewire driver.
Mike Nielsen
Old 01-02-2007, 06:58 PM
Marcus S.'s Avatar
Mike Nielsen
Hi Mike
What's your old firewire driver version?
Do you checked if your Windows IRQ are using diferent IRQ to your Firewire PCI card.
( control panel>system>properties>hardware>manager - you can to show only IRQs )
Blue Screen error on D-show David Colella VENUE Live Sound Systems 9 09-02-2012 08:26 AM
Blue Screen Error - Win 7 and PT LE 8.0.3 Vitor Fonseca 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 05-26-2010 03:35 PM
Help! Page Fault Error Message w/Deltafw.sys file Meanclown Pro Tools M-Powered (Win) 0 08-25-2006 04:51 PM
Locks up with blue screen error. rparts1 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 08-29-2005 10:42 PM
invalid page fault at kernal32? jim jedlicka 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 02-02-2002 01:34 AM
