Transfuser audio Drag & Drop in Windows 7 pro?
Hey All,
Just getting into using Transfuser... lovin' it so far... However, I watched Russ's video showing drag & drop of PT audio into the Tranny "drop track audio here" section... but no love on our system... When I take a 2 bar drum groove from a stereo audio ch. & try to drag/drop into Tranny on its own Instrument track (stereo), I get nothing. No import dialogue, as Russ shows in the vid... nada... it just physically moves the audio in the PT edit window??? Tranny 2.0, Windows 7pro, PT 11.1.3 (both HDX & non-), rest of specs in handle... Much appreciate any help... it must be something pretty simple. Thanks!
-C' ya' Rick MacPro 7,1; 16 core OSX 13.5.2 PT 2023.9; Eucon 2023.6 Dock/S1/2x iPad |
Re: Transfuser audio Drag & Drop in Windows 7 pro?
I believe that video is pre 11. 11 changed some things and D&D is at least broken if not dead.
... "Fly High Freeee click psst tic tic tic click Bird Yeah!" - dave911 Thank you, Craig |
Aaaaahhh... Bummer !
Well, that at least explains it. Thanks much, Craig!
Is user account control ON or OFF
Brian Windows 11 Pro | macOS 12 Pro Tools 2022 benonistudio.com Youtube Channel - benonistudio Plugin Deals @benonistudio |
Hey Brian...
Yeah, it's running as an admin... UAC is off. Thanks!
It's not allowing me to d&d anything into the Slicer Synth module either? (contrary to the manual) and I don't see any "import" command path in any of the drop-downs... I still love it for building grooves/beats, but obviously, it was designed to allow user-audio to be incorporated into that process...
OK... think I've got this solved.
If anyone else runs into this issue, hopefully the following solution will help: 1) In PT create your audio loop. 1/2/4 bars. 2) Select that loop n the Mix window, go to your Clips bin, Right click on the selected loop & "export Clip as files". 3) In the Export window, choose your settings, then for "Destination Directory" choose the "Bounced Files" folder in the PT session that you are using Transfuser in. (I'm assuming that dropping this in your "audio files" folder would work as well?) 4) Then open Transfuser & use the Audio tab to browse to your "Bounced Files" folder. This WILL allow you to Drag & Drop it into the "Tracks Pane". 5) The prompt screen for how you want to use the file (in my case, as a Slicer) will then be called up. Once you choose the method, Voila' ! your track is there to use. Rather cumbersome, but it works... would love to hear a simpler method...
So, yes, the process you mentioned above is what you have to do. Export the clip to a file, then import it to the VI you want to use it in. What I've started doing is exporting clips to a special file and just building up my own little library of loops and beats. It only takes a few seconds to do it. If you keep them all in the same file, they should be easy to find each time, too.
"Never believe anything you hear in a song." Tyrion Lannister, Game of Thrones Owner: Dragon Rock Productions LLC |
Again I haven't tried this with Transfuser, but for dragging in audio to Pro Tools, that's what works for me.
Can't Drag and Drop wavform from transfuser in Pro Tools Edit window | SSB | Pro Tools 10 | 2 | 08-09-2016 07:45 AM |
How to drag-and-drop in Windows | colourednoise | Windows | 3 | 07-12-2013 01:53 PM |
AIR Transfuser Synch Issues with Drag & Drop Loops into Pro Tools 9 | NAJM | macOS | 6 | 02-11-2011 04:03 PM |
Windows Explorer drag and drop audio files to PT8.0.3 | Buccanears | Pro Tools TDM Systems (Win) | 9 | 03-20-2010 09:05 PM |
Transfuser Drag and Drop Tricks | RussUK | Virtual Instruments | 0 | 10-04-2009 02:45 AM |
