PT9 teething problems
Hi all,
Im currently on my second week of using pt9 and seem to having no end of troubles since crossgrading.Heres a list of frustrating problems iam hitting so far.If anybody can help me, plz let me know what iam doing wrong. note: Iam running sessions that worked fine on PTMP 8.4!! Issues Cpu error when only using 3 (compatable) rtas Random distortion noises while recording after 20 seconds m audio 2626 inputs 1/2 are replaced by built-in input 1/2 -6101 error when trying to bounce Macbook pro 13" (10.6.6) 2,26 Ghz Intel Core 2 Duo / 2 GB 1067 MHz DDR3 1TB FWHD M Audio 2626 |
Re: PT9 teething problems
Mac OS X requires 1GB of RAM.
http://avid.custkb.com/avid/app/self...p?DocId=380535
Buy more RAM.
| Logic Pro 9 | Reason 6.5 | Pro Tools 10 | MOTU UltraLite mk3 | RME ADI-2 | Summit Audio 2BA-221 x 2 | MOTU 8pre x 2 | | Mac Pro (4,1) 2.26gHz Xeon x 2 16gB OS X 10.7.4 | Macbook Pro (8,2) 2.2gHz i7 Quad 16gB OS X 10.7.4 | |
More RAM is always good.
D a n t h e I n c r e d i b l e S o u n d M a n "Svetlana" v1 - 4.2GHz i7, 16GB RAM, OSX 10.7.4 Liquid Saffire 56 - PT10.2 - BFD2, VCC, Duende Native, Play 3.0 _C U R R E N T-D V E R B-S C O R E:515 |
Aggregate I/O is not selected on hardware, it shows profire 2626 yet in my track mixer its showing built-in I/O for input 1/2 then 3 to 26 on my profire.
I'll wager this is just the name of the path in the I/O setup. Unless you reset this (either on startup or in the setup->I/O menu), it will have that name until you change it.
The name of the path has nothing to do with the actual output being used. For example, I could name the output path for outputs 11-12 "George" and when I go to assign a track's output, I would see "George" in the dropdown instead of ""Output 11-12"
www.andersonsoundrecording.com |
Q: Does Pro Tools 9 Support Aggregate Audio Devices in Mac OS X? (FAQ added 12/1/2010) A: Mac OS X device aggregation of audio I/O hardware is not officially supported in Pro Tools 9. While certain configurations may work, they were not tested and qualified by the Pro Tools development team. The only exception to this rule is the "Pro Tools Aggregate Device" that is created upon launching Pro Tools to provide users of built-in Mac hardware with simultaneous record and playback capabilities. Good thinking. Probably right.
I too received poor performance results with my crossgrade install (essentially a fresh install - ie. no previous version of PT on the machine). I couldn't throw many plugs on without overload errors ... my fix was to read the link in Avid customer support around machine setup. I unistalled Pro Tools. I set up a new admin account on my machine with pretty much everything off (Airport, bluetooth etc.) and no 'bells and whistles' software. I installed Pro Tools on that account, and I've had no probs. Prior to this my machine would crash around 30%, easily. Since that fix I have run up to 60% System Usage!! (At that level I do need to move the engine to 1024) RAM will also help (I increased mine up to 6GB, go at least 4GB).
hope that helps! --------------------------------------- PT9 MacBook Pro 2.4Ghz, 6GB RAM Digi 002R MOTU 896 Apogee Duet Mbox 2 |
You might check the rights of your preference folder in the library folder of your system. "everyone" should be "read and write". PT can have troubles when "everyone" is on "read only".
MacPro 2x2.8 Xeon 6GBRam, 10.6.7 + 9.0.2 HD2 + C24 + Mercury V8 + Soundminer HD+ -- iMac 27", 10.6.7 + 9.0.2 LE Complete -- MacMini 2Ghz, 10.6.7 + 9.0.2 LE Complete + Mercury V8 |
Imac Pro 27" 10-core with a LG 4K for a second screen OS 10.14.4 Pro Tools 2019.6 UAD Apollo X8P With an extra 8 channel ADAT using a Focusrite Liquid Saffire 56 UAD Twin duo UAD TB3 Octo Satelite Focal Twin Be monitors samsung T5 and Gdrive |
Teething Troubles | Folkybass | Getting Started | 1 | 07-08-2013 06:31 AM |
Midi Studio Setup problems & Plugin problems | J Nauti | MIDI | 0 | 03-02-2010 11:04 AM |
Computer Problems vs Pro Tools Problems | mudlake slim | Pro Tools M-Powered (Win) | 1 | 07-14-2006 08:09 PM |
Rewinding Problems, Cutting & Pasting Problems | Nikki | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 07-22-2005 01:19 PM |
PC Probe problems. Any overheatingg problems with Digi 001 | Ajay | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 03-03-2002 05:30 PM |
