Re: Space AAX DSP not working
So I was interested in having TL space since I've used it before....but would much prefer a solution that uses Valhalla, Seventh Heaven, UAD reverbs, etc. that still allows me to track with DSP while monitoring an Aux with a native reverb (or more dialed in DSP enabled verbs). Is there a good way to do that? |
If you are using DSP Mode Safe and that's breaking the DSP flow, can you elaborate on what that means?
Kyle Splittgerber Senior Principal Product Designer Avid Berkeley, CA |
Edit to add: Tried this tonight, exactly what I needed...VERY cool, thanks! Last edited by HeySchlitz; 05-26-2021 at 12:55 AM. |
Speaking of DSP reverbs, there is a bug in Revibe DSP (18.10), when not automated your session recalls the wrong ER setting when reopened (depending on the preset). More details here https://duc.avid.com/showthread.php?t=407455
@Kyle or anyone else, can you confirm this is also happening on the Carbon? Will this ever be fixed at some point for HDX users? Now with the hybrid engine coming we might give DSP another shot or ditch it altogether. Fixing this would certainly help. (sorry for the slight hijack) |
#16
Great!
#17
I thought about going through all the Carbon forum posts and seeing what you had and hadn't replied to, but that's pretty extreme. If you're confident that you are responding to a wide range of questions and issues, then perhaps I'm mistaken, or at least selective about what I recall, and you have my apologies. On the subject of Space AAX DSP, there are a few endemic issues here. Marketing - the pages on which you advertise your products - should reflect reality. This plug-in, paid for by people, doesn't work on Carbon. It should say so on the product page - also know as a 'marketing' page. Leaving out undesirable shortfalls is not honest. Secondly, it should work, but it doesn't, but you only intend to fix it if enough people make a fuss? I can't tell you how wrong-headed this reasoning is. If you can't see that, or if Avid as an organisation can't, then I'm not going to be able to change the way things are done by complaining here. As far as the 'coherent product set' comment goes, the limitations of compatible versions of MacOS, lack of external firmware upgrade control (meaning only recent and very buggy versions of PT work with Carbon), proprietary AVB standard, 'spare' Ethernet port, no product roadmap, it all just adds up to something I can't feel confident about buying. But that's ok, I haven't bought one. Others have, and I wish them luck. And I hope you keep improving it and over time there's a good version of MacOS and PT which align to make it super-solid. Dominic |
#18
All good. Thanks for apologizing. Regarding Space, I appreciate the input and I can speak with the team about your suggestion. The decision to not fix the bug yet is really about priorities. The team works hard to provide the best experience they can and to fix the most urgent issues as soon as possible. And, it's not that we don't want to ever fix the issue. It's that we don't want to fix it before making improvements that can benefit a larger number of users. For example, preamp control from Pro Tools has been a much more popular feature request from users I’ve spoken with. But, let’s test that to see if that’s changed... For all of you who have a Carbon unit, which is more important to you: Controlling Carbon preamps from Pro Tools or enabling Space to run on AAX DSP? Regarding the complaints about the product, I'll address each one: Limitations of compatible versions of MacOS We support both Catalina and Big Sur. Can you articulate why this is too limiting? Lack of external firmware upgrade control (meaning only recent and very buggy versions of PT work with Carbon) Carbon includes Pro Tools software which provides the firmware update on launch, so there’s not a scenario where a user can’t upgrade firmware. Every new hardware product requires matching software to run its new features. This is going to be the same for any hardware product that requires software support (not just audio products). So, implying you can’t run old versions of Pro Tools with Carbon isn’t really a drawback - it’s just technically impossible. Proprietary AVB standard I assume the downside here is that you can’t currently connect it to 3P AVB interfaces? Or, is it something else? 'Spare' Ethernet port Is the implication here is that you want to connect it to a second Carbon device? No product roadmap In general, we don’t share roadmap plans. In my experience, this is standard for the vast majority of companies. Are there companies building audio interfaces who have publicly shared their roadmap? What audio interface(s) do you use today? Last, I know some resellers offer demo units. If you ever decide to check one out, and get hands on experience, I’d be curious to hear your feedback.
#19
Only 16 ins at 96kHz is way too few to be usable for tracking a band. But at 48kHz you're fighting the high latency that most 3rd party AAX DSP plugins add. #2 Space DSP DSP convo verb is a must since native latency is so high. At 256 buffer it's about 20ms in to out. Even if it were only for reverb 20ms is a lot of predelay... #3 Preamp recall It'd be nice, but I use outboard pres for the most part. Quote:
#20
Other features I'd also rather see than Space support: - Being able to set the Mac system volume when routed through the Carbon. - A small footprint expansion unit that acts as a monitor controller with a headphone output and guitar input. Since you've added Carbon preamp control, I I no longer need to sit near the Carbon - Looks like the levels move when PT isn't launched but something is connected to an input (like a keyboard)....being able to monitor that would be sweet for when you just want to play but don't want to launch everything. Bonus points for supporting ADAT inputs too. (I also want a pony). Carbon has been a stellar interface! It's really well thought out, sounds awesome and I'm sure you guys have great plans for it....looking forward to seeing where it goes but it's great already IMO! |
Command-space bar not working | zoff | Pro Tools M-Powered (Mac) | 19 | 09-05-2020 07:43 AM |
Space-BUG ;) Snapshot automation from TL-Space to Space not working | simplex | AAX Plug-ins | 7 | 01-19-2017 03:55 PM |
Space Rental is not working | Davidtrom | Licensing & Accounts | 4 | 01-31-2016 10:57 AM |
Ctrl+Cmd+Space not working right in 10.3.... | David Hardie | Pro Tools 10 | 4 | 10-26-2012 03:33 PM |
TL Space not working on Mac running OS X 10.6.6 | zemogh | macOS | 15 | 02-16-2011 02:39 PM |
