Re: MTRX Studio doesn't Power on
SOLVED. In my case there was an issue with they way they were conditioning the power from the facility's isolation transformer. Just in case anyone runs into this in the future, here's what happened and how they resolved it: "Guys, here is what I am quite sure was going on. The equipment you are plugging in has an “Equipment ground” internally attached somewhere inside the case and because we have an isolation transformer the equipment was losing it’s reference. So like a standard transformer we now bonded the Neutral and Ground on the load side of the Transformer and that takes care of the problem. This isolation transformer is acting more as a power filter rather than a full isolation such as we might see with medical equipment."
I am having the same issue, has happened twice now with the MTRX Studio not powering up. The power button is orange but it won't switch on. Nothing has changed in my setup since last night.
Greetings,
Have you tried to disconnect the mains, let it sit for a few minutes, then reconnect and power on? Also - any idea what firmware you had installed in this unit? best, Jeff |
Having same problem here, orange light on but won’t power up. It has happened twice before and eventually resolved itself…not exactly ideal. Firmware is current.
I’ve been having similar problems with my mtrx Studio, happens every few months and I haven’t found a solution other than to disconnect everything and plug it in a different building. My mains is clean and no idea why it only happens a few times a year. Just happened again and my previous “solution” hasn’t worked. Anyone figured this one out?
Difference between MTRX and MTRX Studio? | snowplaysmusic | Pro Tools | MTRX & MTRX Studio | 4 | 11-26-2022 09:48 AM |
MTRX MTRX Studio Forum Section? | off the wall | Pro Tools | MTRX & MTRX Studio | 2 | 05-08-2022 04:20 PM |
MTRX Studio tuning v MTRX SQP card | Goombot | Avid Pro Mixing General Discussion | 9 | 07-15-2021 12:00 PM |
MTRX Studio doesn't show up in Dante | Erdem Yetim | Pro Tools | MTRX & MTRX Studio | 5 | 07-13-2021 03:51 PM |
MTRX Studio doesn't show up in Dante | Cheesehead | Pro Tools | MTRX & MTRX Studio | 5 | 12-02-2020 09:02 PM |
