Go Back   Avid Pro Audio Community > Legacy Products > Pro Tools SE and Essential (Win)
Old 02-16-2010, 11:34 PM
MUKULIA DESIGN MUKULIA DESIGN is offline
Question MIDI DRUMS/BASS. how to eq, reverb, delay etc.
im trying to figure out the SENDS A-E. not sure i undersand it. at all.
and can i get eq, compression, reverb, delay etc. on midi drum and bass???
Old 02-18-2010, 12:35 PM
Jared Jared is offline
Default Re: MIDI DRUMS/BASS. how to eq, reverb, delay etc.
Check out the section Mix and Change your sounds in the Intro to Pro Tools guide. Also check out the free tutorial videos at www.digidesign.com/dtv; go to the Introduction to Pro Tools channel. The video on Mixing, EQ, and bussing shows how to setup and use insert and send FX.
Yes, you can add effects and processing to software instrument tracks.
Old 02-18-2010, 10:22 PM
TOM@METRO's Avatar
Yep there are a ton of videos on this that will help you more than us typing a bunch of abbreviated clues.
~ tom thomas
Formerly hobotom
Pro Tools Ultimate 2021 HDX
HD Omni and 192 I/Os
Windows 10
Intel Hexcore i7
All Samsung Pro SSDs
Ampex MM1200 2" 24 trk tape
www.metrostudios.com
Old 02-19-2010, 02:50 PM
can u send some links to these videos. this is rather new stuff to me and im not even sure what titles/subjects to search.
Old 02-19-2010, 02:54 PM
im not sure if this is CORRECT. but it worked somewhat well for me.
not knowing yet how to EQ AND EFFECT MIDI.
i just pencil edited in my MIDI DRUM AND BASS TRACKS. then BOUNCED them to disk as MONO RIGHT AND LEFT.
then IMPORTED those 2 tracks into new AUDIO TRACKS synched with my original MIDI d&b tracks.
then i can use AUDIO EQ & EFFECTS to fatten up the audio drum and bass and mix them into the MIDI.
Old 02-19-2010, 03:04 PM
Your MIDI data should be recorded on an instrument track; the instrument track that the software instrument is inserted on. You can add audio effects and plug-ins after the instrument plug-in, and you can also setup sends from the instrument track. This is quicker, easier, and you've got the freedom to edit the MIDI data at anytime.
Old 02-22-2010, 03:15 PM
ok finally found it. and got a vocal reverb send working.
similar info found here
http://akmedia.digidesign.com/suppor..._v80_56116.pdf
Midi Drums and bass (Xpand2) lose sync-aye carumba scrnplyr macOS 4 04-02-2012 12:32 PM
Reverb for Drums and El Bass DonaldM Tips & Tricks 12 08-02-2010 10:06 AM
Syncronizing Midi Bass & Stereo Drums? dts.music Tips & Tricks 1 01-27-2007 10:43 PM
Reverb on bass guitar..... thoughts? tlester Pro Tools TDM Systems (Mac) 8 08-01-2006 09:43 AM
How do I record bass/drums through MIDI into Protools?????!??!? Shan Plourde General Discussion 2 01-20-2001 01:46 AM
