Possible i5 Build for PT LE 8.0.1 / 003 Rack
Would you serious hardware guys review for any Digi-undesireables in this configuration? I would totally appreciate that.
I own a 003 Rack (Note - I have the approved Siig firewire card already). Intel Core i5-750 Lynnfield 2.66GHz LGA 1156 95W Quad-Core Processor Model #:BX80605I5750 MSI P55-CD53 LGA 1156 Intel P55 ATX Intel Motherboard - Retail Model #:P55-CD53 Kingston HyperX 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Model #:KHX1600C8D3K2/4GX Western Digital Caviar Blue WD3200AAKS 320GB 7200 RPM SATA 3.0Gb/s 3.5" Internal Hard Drive - OEM Model #:WD3200AAKS Western Digital Caviar Green WD5000AADS 500GB SATA 3.0Gb/s 3.5" Hard Drive - OEM Model #:WD5000AADS XFX HD-435X-YAH2 Radeon HD 4350 512MB 64-bit GDDR2 PCI Express 2.0 x16 HDCP Ready CrossFire Supported Low Profile Ready Video OCZ StealthXStream OCZ600SXS 600W ATX12V / EPS12V SLI Ready Active PFC Power Supply Model #:OCZ600SXS LG 22X DVD±R DVD Burner Black IDE Model GH22NP20 - OEM Model #:GH22NP20 Microsoft Windows Vista Home Premium SP1 32-bit for System Builders w/ Tech Guarantee - OEM Model #:66I-03510 (includes free upgrade to Windows 7) COOLER MASTER RC-690-KKN1-GP Black SECC/ ABS ATX Mid Tower Case Model #:RC-690-KKN1-GP |
Re: Possible i5 Build for PT LE 8.0.1 / 003 Rack
While I haven't seen any i5 builds yet I would assume the are good.
But since i5 has hyper threading disabled I would recommend going for i7 860 (1156) or i7 920 (1366). For a bit more money you'll get quite a significant performance gain. Its has been a long lasting tradition to go with either Asus, Gigabyte or Intel motherboards. Just another thing to consider. Please keep us updated on your build.
i7 2600K @ 4.4GHZ -- Intel DP67BG B3 -- 8GB DDR3 1600 -- Crucial SSD PTLE 8.0.4cs2 -- DIGI 003R -- DV toolkit -- Waves 9 |
Careful with those "green drives...they have a habit of hibernating whether you want them to or not...
Okay - avoid the "caviar green" - so two "caviar blue" would be fine.
And I move to the gigabyte motherboard. I'll look to see if I can move up to the i7 - and ProTools supports hyperthreading (or doesn't not support it - you know ProTools, I mean). |
PT8 does support hyperthreading. +1 for ditching the green drive. Actually, the blue is fine for system but the WD Black is even better for audio with its 32meg cache.
If you haven't checked out the "i7 builds - specs and results" thread yet you definitely should. lots of good info on setup and optimizing your system, and I'm sure there are lots of folks interested in the performance of a new Lynnfield rig. |
Another +1 on the Giga board, the Black drives, and the i7.
Make sure that approved FW PCI card you own is going to work....A lot of newer boards are showing up PCIe only. If you need a PCIe FW card ADS makes one that I have used with PT.
Scott Formerly Hobo Wan Kenobi Core 2 Specs Page ASUS P6T6 Revolution | i7 930 | 12GB OCZ DDR3 1600 7-7-7-20 | PTLE 10 | CPTK | 003 | Presonus D8 | 11Rack | Alesis AI3 | Presonus HP60 | Mercury + Studio Classics | Sound Toys | MasseyPack | Axiom61 | MAudio Keystation Pro 88 |
MSI P55-CD53 - 3 PCI slots Gigabyte GA-P55M-UD2 - 2 PCI slots Asus GA-P55M-UD2 - 3 PCI slots |
looks good - on board TI TSB43AB23 chip PCI for your SIIG card if you want that instead of the onboard less memory to buy as not triple channel parts binned cpus and mild overclocking will most likely get you i7 performance whilst saving a little cash. |
New Build Review! Based on Mano/Ame? and SPCR Fanless build | Calipoop | Windows | 4 | 11-16-2011 09:38 PM |
003 rack comp build. Need some info... | geekkiller | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 11 | 04-18-2010 02:32 PM |
003 Rack - Windows 7 - New Build | lowlights | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 10 | 11-13-2009 03:03 PM |
Build your own isolation rack case? | bwherry | General Discussion | 7 | 11-28-2003 11:18 PM |
To build or not to build? Money is the question... | storm-01 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 8 | 09-18-2003 09:13 PM |
