Old 06-25-2006, 11:58 PM
n3xus n3xus is offline
Default LE MIDI Problems
I can't seem to be able to play any plugin instruments with either of my MIDI keyboards even though both keyboards show up on the MIDI input list and I can see MIDI data being recorded to a track. There is just no sounds comming out from the Instrument. I have tried using Sample Tank 2 and Battery 2 and I have this problem with both of them. Any suggestions?
Old 06-26-2006, 12:37 AM
Default Re: LE MIDI Problems
Hi n3xus
Check MIDI Thru and check that the Audio Input on the Instrument track, if using a Instrument track, is assign to a valid Input.
filosofem
Aaron Mulqueen - 001 HD Native
Old 06-27-2006, 01:38 AM
Thank you, checking the MIDI thru worked. Why did that make it work?
Old 06-27-2006, 01:53 AM
When MIDI Thru is not enabled, Pro Tools' can not communicate with the Controller, nor the MIDI Device, enabling this, results in communication with Controller and Device.
filosofem
Midi Studio Setup problems & Plugin problems J Nauti MIDI 0 03-02-2010 11:04 AM
Problems with Midi sound / Midi Controller joe_04_04 MIDI 2 07-16-2009 12:43 PM
MIDI Problems with Axiom 25 MIDI Controller jasonguitar Pro Tools M-Powered (Win) 12 04-03-2007 10:04 AM
Help...Problems with midi my cardboard box 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 9 02-27-2004 06:35 PM
MIDI NOTES DISSAPEAR!!?? WIERD MIDI PROBLEMS ManhtnProjct Pro Tools TDM Systems (Mac) 2 10-29-2001 08:39 PM
