Inconsistencies During Automation
Hello Avid,
Good afternoon. How are you? Hope all is well. Happy Thanksgiving. I am having a bit of a dilemma automating regions, specifically volume (just the volume). I want to put up the volume on a region by using two dots or selecting the region and increasing the volume on that region using the smart tool. Have there been multiple reports about the volume going up slanted rather than squared at times? I ask because it's very inconsistent, to the point where I have to latch and increase the volume, listen to the region, which is too much time. I've attached a photo of the slanted volume automation line as I am increasing the volume using the smart tool. Any help would be greatly appreciated, Thanks.
Take care brush your hair, Rey https://r-e-y.com/ macOS Ventura Pro Tools 2022 iMac (Retina 5K. 27-Inch, 2020) Processor 3.6 GHz 10-Core Intel Core i9 3.6 GHz Dual-Intel Core i7 16GB ram AMD Radeon Pro 5700 8GB Shure SM7B Mic Pro Tools | Carbon Komplete Kontrol M32 AKAI Mpk3 Mini KALI Lp 6 (2) |
Re: Inconsistencies During Automation
Your best bet is to change your method. Instead of swiping across and trying to move the volume line across a selection, instead, drop break points and drag each to the level you want. Things that will help this action: Enlarge the track vertically and use the Ctrl key to select FINE mode.
I think it's because you already have a "dot" where you're already trying to raise the Volume.
Select your clip, in volume view hit Command+/ . This will put breakpoints on the clip boundaries.
Then use the smart tool that will turn into trim when you hover over the volume. Adjust as needed. |
Or use Clip Gain if you’re automation aims only a clip and not the whole track.
Best Mark
Mac Pro 2010 3.66 GHz six Cores, HD Native, 192 I/O, Avid Dock, Artist Mix and Pro Tools Ultimate Mac mini 2018 i5 64 GB RAM, RME Fireface, Pro Tools 2021, Euphonix MC Control MacBook Air 2020 (M1) 16 GB RAM, 1 TB SSD, Zoom U-44 and Pro Tools Ultimate |
GR metering inconsistencies with Waves | wolfhound | Pro Tools 11 | 1 | 12-11-2013 10:12 AM |
CLICK TRACK INCONSISTENCIES... | nrsv40 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 02-04-2008 06:33 PM |
experience inconsistencies in running 002 and external FW | Jenk2k | Storage Subsystems | 0 | 09-05-2007 07:48 AM |
Anyone have timing inconsistencies with Mach 5? | gjp | Pro Tools TDM Systems (Mac) | 13 | 05-11-2006 09:35 PM |
Fader inconsistencies | jackruston | ProControl, Control|24, Command|8 | 0 | 09-17-2001 05:17 AM |
