Old 11-17-2021, 03:59 AM
digiplex digiplex is offline
Default Bouncing not aligned
So what’s happening here?
https://youtu.be/oTlOq6SsuUI
Old 11-17-2021, 06:35 AM
its2loud its2loud is offline
Default Re: Bouncing not aligned
What’s happening is a 20 minute ramble about an issue that really isn’t an issue.
While the bounce does seem to appear to render everything late in the selection, he is running his delay compensation on his master track. He even acknowledges this. Also, he doesn’t show his source bus for bouncing. We have no idea if he is even routing anything correctly in his session.
If that Master Track is bussed directly to his physical outputs and he is bouncing using those outputs as the source, there will be delay compensation on that bounce if it's turned on in the Master Track
This is a complete ramble solely to get people to subscribe to his channel. IMHO
Old 11-18-2021, 08:23 AM
Zenguitardude Zenguitardude is offline
While the bounce does seem to appear to render everything late in the selection, he is running his delay compensation on his master track. He even acknowledges this. Also, he doesn’t show his source bus for bouncing. We have know idea if he is even routing anything correctly in his session.
Sorry the video is long, never done one like that before, but I've been doing this for a long time and that's why I put chapter markers in so that people could skip past things that I'm saying and thinking and get whatever it is that interests them the most . My personal interest is in trying to find a solution to a problem and I didn't post this here to the DUC.
I guess I find it interesting that rather than actually looking at the problem that I described as being a combination of both technical and workflow you choose to reduce my perspective and effort to some sort of self promotional scheme? I know how to buss audio I've been doing it for 40 years at some of the best recording studios in the world. I think one of the reasons that I don't like putting out these kinds of ideas or posting here is that, in the old days at least, recording engineers and people who are in technical production would actually talk about problems that they found without trying to discredit the other person and actually look at the idea. I am working on this issue with a number of extremely smart and experienced people in the field that we work in. If you were actually to look at what I posted you would see that I am describing a technical problem that I can drive every time, everything is set up correctly, and a workflow issue that a lot of the younger guys and a lot of the production houses are utilizing that could be causing this kind of a problem.
Old 11-18-2021, 08:38 AM
You posted a banner across the bottom of the video for the entire length promoting yourself and your website and you wanted people to subscribe to your channel.
To me that says self promotion for self gain. If you really just wanted it to be informative with no personal gain, you would have just posted a generic video showing a problem. Which again, what's the problem here? That the delay compensation is actually working?
And you claim to know routing but yet have not provided anything to back up that claim considering your allegation of something being broken in Pro Tools.
Perhaps a more helpful video would be to go through your routing and show the buss path that you're offline bouncing so the viewer can deduce whether or not it's an actual technical issue.
I'd go back and watch the video over again to see if I missed anything but you made it private.
Old 11-18-2021, 08:51 AM
I took it down and made it private to work with guys I know and respect. I'm too old and too tired of these kind of Internet-based discussions that actually go nowhere, and I'm dealing with this with people I know who are knowledgeable and experienced and don't have a lot of attitude about trying to figure out a problem. The banner was an OBS thing and I had already recorded the whole thing before I realized it was burned into it. Again I had not made one of these before and so it's just not perfect or at least up to your standards of how things should operate. Your fundamental perspective is based on how you see the world and how you work in it, not mine. You focus so much more on things that have nothing to do with the content, and I don't really want to argue with you because I don't have the time or the energy to. I'm looking at a problem that I think affects a lot of people potentially and I'm going to see if I can find a solution, but I'm not going post about it here and I'm not going process it here with you because I don't really know who you are or care what you think. I did not post a video here, and I did not ask for your response, I am just responding for the last time because I take exception to the way you were characterizing my motivations regarding what I posted.
But just to make it clear, the problem that I am trying to describe is; not just that delay compensation works and causes an offset, but that workflow process for a lot of people is ignoring that delay compensation works. That people are moving stems and tracks back-and-forth and potentially losing sync because this issue is occurring. It's pretty simple and straightforward. Also, delay compensation is not really working because the audio should exist in the same place as it does without maintaining the region definition. If the region start time is exactly the same and the audio has been offset by an amount required for delay compensation or lookahead processing then that's causing the potential sync problem.
Old 11-18-2021, 09:02 AM
The question I have with regards to your video and process is.. Are you using the Master Fader on a physical output or on an internal buss?
There has been some discussion in the past that Master Faders on physical output paths do not compensate for any plugin delay. Therefore, if you're choosing the actual hardware output as your offline bounce path, this would explain that offset.
If you recording the 2 mix internally in Pro Tools to a Record Stem track being fed with a 2mix stem buss and had your Master Fader with lookahead plugins assigned to the 2mix stem buss, would you have the same issue whether real time recording of offline bouncing?
I applaud the purpose of the video and am all for working together to achieve a solution to potential problems.
What you describe as the purpose to your video was not the take away for me on first review. To each his own I suppose. The world is free to agree or disagree. That's the beauty in discussion.
Old 11-22-2021, 04:39 PM
In a session with delay compensation on and a heavy processing mix bus in place it seems rather obvious to me that there’s a delay. Now I asked you to import that bounced file into a new session to troubleshoot but you wouldn’t try that. In an empty session with zero plugins and delay compensation off , it should snap to grid.
Either way as I said earlier the workflow is to line up the click on import of files using the grid of your preferred daw which makes this irrelevant. If you want the daw to process at near zero latency you need an hdx rig. On native it’s delayed processing for heavy lifting. Anyone with experience in Pro Tools understands latency on processing and this should also hold true for all of those extremely knowledgeable engineers you claim to have discussed this “issue” with!
Old 11-23-2021, 09:18 AM
What is your problem exactly? You seem to be taking this personally? I don't "claim" to be working with experts, I am working with experts who are capable of seeing the problem/issue and working with it. I have been working with cutting edge DAW's since the late 70's. I have worked at some of the best studios in the world and in my experience people who cared about this kind of thing discussed it politely, as I am finding with people with a lot of knowledge and experience who can see what i am pointing to. So, since you seem unwilling or incapable, I will reiterate what I point to in the simplest possible terms:
There is an issue that is 1/3 technical, e.g. a delay compensation/lookahead processor issue that causes audio to be delayed and yet the region strat time remains the same. This is not "Latency" per se because it is not a throughput issue. The second part of the issue is that this amount of compensation can vary depending on how stems and track are being processed, and the 4rd important aspect is that many people who are moving assets by creating stems and just exporting tracks and stems with no sync markers, are assuming sync because of the start time of the associated regions. Why you cannot hear that this might cause some people problems, especially less experienced mixers or video editors or sound designers or people doing complex mixes for audio post, is beyond me.
Yes there are workarounds and yes I am looking at this amongst a group of experts I know and respect after 45+ years working in these areas. I did not ask you to re-post the video, which I have removed and made private so that i can show it to people who actually want to solve it. I have not made a big deal out of it, but it is something that came up on several large sessions, caused some problems and I am dealing with it. I don't know you and I don't care that this seems to have ruffled your feathers, but it amazes me how much negativity and attitude folks can have when the possibility of polite discourse and exploration can occur. I am exiting this thread, have deleted the video and don't care what you think. I wish you luck in your career in audio production.
Old 11-24-2021, 07:42 AM
Why are you working with delay compensation on and expecting copper wire processing? Just tell me?
Old 11-27-2021, 09:56 AM
2 things to consider:
1-delay on a master track is not compensated for(usually does not need to be).
2-as a quick experiment, instead of Bounce to Disk, select the master track and commit it. I don't know exactly what will happen as I never dig this deep into things that don't affect my work, but I'd be interested to hear if it changes the outcome.
Paying to have drums aligned perfectly WWJD Tips & Tricks 14 12-11-2014 09:48 PM
Track Names Aligned to the Left josh_hopwood Tips & Tricks 2 04-30-2010 06:49 PM
recorded tracks not aligned bordur 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 12-27-2007 09:35 PM
mis aligned loops ? Masterpiece 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 09-09-2006 07:51 PM
192's not time aligned. is this a known issue?! vieris Pro Tools TDM Systems (Mac) 15 09-04-2006 01:45 PM
