#6921
Re: i7 Builds - Specs and Results
Many thanks! Just the kind of info/reality-check I need to get started.
Once I get down to an exact proposed system I'll check in again here before giving NewEgg my credit card numbers...
Pro Tools 2023.6 & 10.3.0 Windows 11 Professional / 64-bit Roland Octa-Capture |
#6922
I am curious about one thing with these builds, which is the performance when using PT to play VI's with external MIDI controller. In my ancient of days current system, there's a lot of VI's such as Omnisphere or Falcon, where I can't set the buffer below 256k ever when trying to play the VI, and usually 512k. That sometimes (often actually) creates noticeable delay issues when playing. So, with the builds you're all discussing, what buffer settings are you able to use when playing VI's controlled externally? 32? 64? Just curious how they perform. Also, do you ever get the "You've run out CPU power" alert with these set ups? Thanks.
"Never believe anything you hear in a song." Tyrion Lannister, Game of Thrones Owner: Dragon Rock Productions LLC |
#6923
No
Desktop build: PT 2020.5 / Win 11 / i9-11900K @ 5.1GHz / 64GB / 4TB NVMe PCIe 4 / Gigabyte Z590 Vision D / PreSonus 2626 Laptop: PT 2020.5 / Win 11 / i5-12500H / 16GB / 1TB NVMe / Lenovo IdeaPad 5i Pro / U-PHORIA UMC1820 Ancient/Legacy (still works!): PT 5 & 6 / OS9 & OSX / Mac G4 / DIGI 001 Click for audio/video demo Click for resume |
#6924
Thanks, Gary. One more question. In looking at the CPU chip at Newegg it says 3.4Ghz. But you said you're system is running at 5.1GHz. Is there a different CPU chip model? I don't understand the difference. Also, it appears that the RAM chips you specified are all currently "out of stock!" Oh joy!
#6925
To run @ buffer 64, a fast CPU helps. The CPU clock is set in bios, and it's actually pretty simple. Manufacturer specs list "base" clock and "boost" clock. Turbo boost is generally not advised for Pro Tools since throttling up or down might adversely affect performance. Disable it in bios. While my particular CPU model claims "boost up to 5.3GHz", I decided to go conservative with a constant (turbo boost off) all-core clock of 5.1. I think the Intel published 5.3 number is marketing hype designed to sell chips to gamers; I'm not a gamer & only want stability. There's a LOT of crazy gamer over-clocker tricks out there (beware), but I found simple/conservative/solid bios settings called "Strategy #2: Traditional Approach" here: https://skatterbencher.com/2021/04/0...d-to-5500-mhz/ I'm no expert on bios, so I simply typed-in these settings like a cookbook, and it worked perfectly! Conservative/safe operating temps, too! By the way, I use air cooling (not liquid) with low-RPM fans and a fan-less titanium PSU; it all runs really quiet. When I pushed "buy" for my build in June 2021 (before 12th gen was available), I went with 11th gen/Z590/DDR4-3600. Intel 9th gen was pretty darn good ... 10th & 11th gen refined/matured that chip technology further ... 12th gen is brand new tech, but it's awesome. I think right now for Pro Tools, you can't go wrong with 10th gen i7/i9 Z490, 11th gen i7/i9 Z590, or 12th gen i5(!)/i7/i9 Z690. These chips provide tons of CPU headroom. (Note: AMD Ryzen & Apple M1 are decent chips too, but I have no personal experience with them for Pro Tools.) Ram: depends on your CPU/MB. If you go 12th gen/Z690, you might as well get DDR5.
#6926
Gary - Thank you so much for all this info. This really helps me!
#6927
Win 11 build:
i9-12900K MSI PRO Z690-A DDR4 (due to DDR5 prices/availability, and having 2x hopefully HDX-capable PCIe slots) Noctua NH-D15 CPU Cooler Kingston Fury Beast 64GB DDR4 3200MHz/CL16 Samsung 980 Pro 1TB M.2 PCIe 4.0 (OS) Samsung 970 Evo Plus 2TB M.2 PCIe 3.0 (Main audio) Corsair HX1000 1000W PSU I already had/ migrated these: Fractal Designs Define R6 case 2x WD Black 6TB GPU (a few options, possibly the Mac flashed GTX780 from my MP to start with) PT confirmed to be working (so "untested"?) and the power is massive, but HDX testing to commence. Fingers crossed...
Windows 11 22H2, Intel i9-14900K, MSI PRO Z690-A D4, 64 GB DDR4 4000MHz/CL18, Corsair HX1000, 1TB M.2 PCIe 4.0, 5TB M.2 PCIe 3.0, 2TB QVO, 2x6TB WD Black, Noctua NH-D15, Fractal Design Define R6 + RTX4070 - PT Ultimate 2023.9 Used to be/ Spare/ DAPS: Mac Pro 4,1 upgraded to 5,1 3,46Ghz 12 Core, 96GB RAM, OS SSD and Sata3 Audio SSD, macOS Mojave, PT Ultimate 2021.10, DAPS 3.7.1 HDX2, MTRX Studio & DAD MOM, HD I/O 16x16, Apogee AD/DA 16X/X-HD and ICON D-Command ES. Last edited by Skwaidu; 11-18-2021 at 08:49 AM. Reason: Typo in the mobo spec |
#6928
12th gen CPUs are socket LGA1700, so you'll need a Z690 MB.
#6929
And that was a typo, fixed.
Windows 11 22H2, Intel i9-14900K, MSI PRO Z690-A D4, 64 GB DDR4 4000MHz/CL18, Corsair HX1000, 1TB M.2 PCIe 4.0, 5TB M.2 PCIe 3.0, 2TB QVO, 2x6TB WD Black, Noctua NH-D15, Fractal Design Define R6 + RTX4070 - PT Ultimate 2023.9 Used to be/ Spare/ DAPS: Mac Pro 4,1 upgraded to 5,1 3,46Ghz 12 Core, 96GB RAM, OS SSD and Sata3 Audio SSD, macOS Mojave, PT Ultimate 2021.10, DAPS 3.7.1 HDX2, MTRX Studio & DAD MOM, HD I/O 16x16, Apogee AD/DA 16X/X-HD and ICON D-Command ES. |
#6930
Preliminary results: HDX2 recognized. I didn't yet have time to try with the DSP mixer and using the 2nd card digilink as well, as I had suspicions about that slot (MSI are unclear if that slot 4 is PCIe 3.0 x4 or x1, even though the seller page stated x4...)
Best Core 2 Series Desktops-Results and Specs | sunburst79 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2416 | 02-19-2013 07:49 PM |
new to pc builds | chazc080488 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 11 | 10-18-2011 07:10 PM |
any p45 builds | fofif5792 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 09-09-2008 12:47 PM |
OSX "builds" | Richard Barrie | Pro Tools TDM Systems (Mac) | 2 | 10-18-2004 08:37 AM |
