Old 11-01-2021, 02:57 AM
Teej Teej is offline
Default Intel Turbo Boost option: "only offline"
At least with my MacBook Pro (and every MBP before it...) Turbo Boost while recording or mixing is a pain (time limited boost, system runs hot/loud/unreliable.) However I have sometimes found value in manually toggling boost on and off for bounces, it can shave minutes off a bounce which adds up during a day.
There should be a "Use for offline processes only" tickbox for Turbo Boost that only enables it for Audiosuite/Freeze/Commit/Bounce (anything else?)
I really should know haha but is there a way of submitting this as a request to Avid?
MacMini M1 (2020) / macOS 13.6.4 / PTU 2023.12 / Avid S1
Old 11-01-2021, 04:54 AM
Cheesehead Cheesehead is offline
Default Re: Intel Turbo Boost option: "only offline"
I recently found switching off Turbo boost improved stability and stopped a lot of crashes I was having.
It doesn't seem to have affected the power of the computer in any noticeable way apart from being more reliable.
Mac Pro 7,1 16 core, OSX 12.7.3, HD-Native TB, Trinnov MC, MTRX Studio, 2xRME ADA-4, Sync HD, AJA IO XT, Avid Dock, Avid S1, PT Control, Soundflow, PT 2023.12
Old 11-01-2021, 11:54 AM
It should be an additional option, maybe there are configurations for which you truly want Turbo off at all times. However I've never had issues with Turboing for offline bounces...it's much faster on my laptops and has been for the last decade. But as soon as I'm working I switch it back off again, it is as you describe much more reliable.
Old 11-01-2021, 12:18 PM
I was under the impression that disabling Turbo boost was a recommended system tweak
Old 11-01-2021, 09:01 PM
For 95% of the time, yes. Doing any work, playback, recording, mixing etc, for stability, predictability, heat and noise it is best to leave Turbo off. However it greatly speeds up any offline process, the only trade-off being more heat temporarily. I have never had any issues turning Turbo on for bouncing other than going home earlier.
Am I not explaining something clearly? I feel like a broken record....
Old 11-01-2021, 09:47 PM
nsureit nsureit is offline
I leave turbo boost in the on position, except when recording [Dell XPS 15]. The fan stays on when crunching a lot of data, but not an issue while mixing. Offline bounces are a breeze.
Old 11-02-2021, 09:10 AM
EGS's Avatar
EGS EGS is offline
TB off. I run all cores at a constant 5.1GHz (set in bios). Works & no variation or throttling ever.
Click for audio/video demo
Click for resume
Old 11-02-2021, 07:19 PM
smurfyou smurfyou is online now
+1
Makes perfect sense.
~Will
Old 11-10-2021, 11:35 PM
Yes you have a desktop with sufficient cooling for these Intel space heaters, this feature is not aimed at you :)
Old 11-11-2021, 10:27 AM
EGS's Avatar
EGS EGS is offline
... Intel space heaters ...
I built my desktop using low-rpm CPU & case fans, fan-less titanium PSU, and no water cooling. It runs very quiet & temps are simply NOT a problem.
Click for resume
Intel Turbo Boost 2021.6 dominicperry Pro Tools 27 06-30-2021 05:35 PM
Intel Turbo Boost Max 3.0 Spyderrp7 Windows 8 07-14-2017 10:29 AM
Intel Turbo Boost causing problems with PT 9? Anyone know how it be turned off? Georgerob Windows 0 11-22-2012 03:13 AM
New Mac Pro Feature - "Turbo Boost" JSR Pro Tools TDM Systems (Mac) 10 03-06-2009 02:19 PM
What's the difference between "online" and "offline" editing ? stuu 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 02-21-2002 03:46 PM
