In the past I have had no issues with running 8-16 Kontakt instruments through a single Instrument track. For some reason I can now only have 2 VIs play through a single instrument track. I can see signal coming from a third VI (and I can record MID data onto the track) but no sound is coming out of the speakers.
So far, I've updated PT to the current version, I reinstalled the driver. I've tried different Playback engines (ASIO4ALL v2 and Mbox) and defaulted the input and outputs on my I/O. I am out of ideas on how to fix this and wonder if this is the correct forum for this question. Thanks in advance. Pro Tools: Studio Version Interface: Mbox (3rd Generation) MIDI Controller: NI Komplete Kontrol A25 and M-Audio ProKeys 88 Processor Intel(R) Core(TM) i7-4770K CPU @ 3.50GHz 3.50 GHz Installed RAM 16.0 GB System type 64-bit operating system, x64-based processor Edition Windows 10 Home Version 21H1 Experience Windows Feature Experience Pack 120.2212.4180.0 Last edited by pjmusiced; 09-17-2022 at 09:00 PM. |
Just to clarify, on my instrument track I am inserting Kontakt with a Session Guitar routed through MIDI channel 2. I have second instrument (bass) going through MIDI channel 3. My 2 MIDI tracks are working and everything is fine. If I add a third instrument (or more) and route them correctly I get signal in the Kontakt window and on the assigned MIDI track, but no sound is coming through my monitors or headphones.
The output on the instrument track is set to Analog 1-2. The default on my I/O Outputs are only Mbox Multichannel Out 1-2 (ASIO4ALL play engine), or Analog 1-2 and S/PDIF LEFT-Right (Mbox play engine). I don't recall if this was the same setting when everything worked perfectly in the past. |
![]() Quote:
MSI Pro Z690-A | i712700k @ 5.1GHz | 64GB DDR4 | 8TB NVMe /14TB WD Black | Audient iD14 | PT 2022.12| Win 11 Pro | Tons of VIs and plugins |
Can one midi or instrument track, trigger, multiple instrument tracks simultaneously? | jamesleonard | Pro Tools 2019 | 5 | 05-24-2019 08:33 AM |
Routing MIDI data from one instrument to another | DAWgEAR | Virtual Instruments | 4 | 01-06-2014 12:43 PM |
Instrument Tracks, Routing Issues, Session Recall Errors etc | alwaysmakingmusic | macOS | 0 | 06-06-2013 11:35 AM |
2 instrument tracks each controlled by different MIDI input/instrument | Midimax | Pro Tools M-Powered (Win) | 0 | 03-20-2012 04:10 PM |
MIDI signal routing for an instrument plugin | Fletchmanxyz | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 08-09-2006 09:49 PM |
