There is always a high pitched noise/beep when my Mbox 2 is on. Is it broken or is there something I can do??
I also get more ands more noise/beep for every digidesign plug in I use in a session... which makes my Mbox 2 useless... Should I just return it or is there something I can do ??? |
bump
please excuse my english...
We had this question before. This seems to be a problem, which only a few users have. I had the same problem. After using symmetric cables from the mbox 2 to my monitors the high pitched sound went away. The sound wasn´t very loud, but loud enough to recognize it. So, first of all check if you are using symmetric cables to your monitors/speakers. Other users also tried symmetric cables, but they reported that it didn´t solve the problem. If you´re working on mac try to disable processor nap and try the general troubleshooting tips, described here: http://duc.digidesign.com/showflat.p...fpart=1#313423 Disconnect all cables from the mbox 2 inputs and all other gear from the power supply (except of your computer and speakers, of course) to find out, if there is a ground loop somewhere. Check out other usb ports and also check, if there could be other electronic devices in your room, which cause the problem (lamp, tv, etc.). If this all fails, contact your dealer. |
high pitched sound? | xcracer41 | macOS | 1 | 02-16-2013 09:22 PM |
High Pitched Wine whenever sound is played | dmusichahn | Pro Tools M-Powered (Win) | 1 | 06-02-2007 08:04 AM |
DEAR DIGI: High pitched whining sound with Mbox?! | Colors | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 9 | 05-08-2005 02:12 PM |
weird high pitched sound from mbox | Thresholdproductions | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 9 | 03-17-2004 07:53 PM |
Powerbook and Digi002 - high pitched whining sound | 1248 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 22 | 12-10-2003 03:46 AM |
