Old 09-22-2010, 01:36 AM
dariusmcgann dariusmcgann is offline
Default Snow Leopard or Not?
I'd be very grateful if someone could give me a couple of pointers here. I'm currently running an LE 8.0.4 system on a macbook pro(specs below) but am upgrading to an imac 3.06gHz with 8gbs of RAM.
My question is; if I go with 64 bit Snow Leopard am I going to run into problems with 32 bit LE? Am I better off installing Leopard 10.5.8 on my new mac?
Thanks in advance for any help,
Darius McGann
Audio Designer. Engineer. Composer.
3.06gHz i3 iMac
12GB RAM
Snow Leopard 10.6.4
Pro Tools 8.0.4
Vienna Instruments Special Edition
Vienna Instruments Soprano Choir
Mbox 2 Mini
1Tb G-Tech Firewire External Drive
M-Audio Oxygen 49
Old 09-24-2010, 04:06 AM
Default Re: Snow Leopard or Not?
Any takers?
Darius McGann
3.06gHz i3 iMac
12GB RAM
Snow Leopard 10.6.4
Pro Tools 8.0.4
Mbox 2 Mini
M-Audio Oxygen 49
Old 09-24-2010, 04:39 AM
mhelm01 mhelm01 is offline
I run snow leopard with no problems. Currently I'm running 10.6.3. It also appears that 8.0.4 is qualified on 10.6.4, although there was no real announcement. Its on the compatibility page.
2.66GHz Quad-Core Intel Xeon
6 GB SDRAM
3 1 TB WD Caviar Black Hard Drives
Eleven Rack, Axiom 61
Old 09-24-2010, 06:04 AM
lemonkid lemonkid is offline
Snow Leopard here with 10.6.4 and 8.0.4
Others prefer PT 8.0.3
Old 09-24-2010, 06:28 AM
CME CME is offline
I upgraded my system to 10.6.4, and it's worked flawlessly. I kept my 10.5 install on an external drive with PTLE 8.0.1, so I can still use my, now ancient, original Mbox.
Dell T5810. Harrison Mixbus 32C. Haven't used PT since 2015 and never been happier.
Old 09-24-2010, 12:04 PM
DRC Music's Avatar
DRC Music DRC Music is offline
"My question is; if I go with 64 bit Snow Leopard am I going to run into problems with 32 bit LE?"
Running Snow Leopard 10.6.4 in 64 bit mode and Pro Tools LE 8.0.4 ... Smooth as glass for me
Pro Tools Ultimate 2023.6
Logic Pro 10.7.8
macOS Ventura 13.3
MacBook Pro (16-inch, 2021)
Apple M1 Max
Memory 64 GB
PreSonus Quantum 26x32 Thunderbolt
Old 09-24-2010, 12:08 PM
John_Toolbox's Avatar
John_Toolbox John_Toolbox is offline
Know that Pro Tools itself is only 32 bit so it won't be able to access all of your RAM by itself, but it will run fine in Snow Leopard. Other programs running separately will be able to access more RAM though.
- John
If a MIDI event triggers a sample of a tree falling and there's no one there to hear it, does it make a sound?
Old 09-24-2010, 05:57 PM
DiegoFox DiegoFox is offline
I had to get used to hitting Command-S more often since upgrading to Snow, as I am experiencing PT crashing (never before).
Old 09-25-2010, 04:11 AM
Will Russell's Avatar
Will Russell Will Russell is offline
Running MacOS 10.6.4 and PT 8.0.4 with no problems.
Will Russell
Electric Wilburland Studio
https://linktr.ee/wilburland
M1MAX Mac Studio OS 14.4.1, PT2024.3, HDX, S1/Dock
M1 PRO MacBook Pro OS 14.4.1, PT2024.3, BabyFacePro FS
Old 09-25-2010, 08:14 AM
Skyflash Skyflash is offline
I just received my SL upgrade today. Reading this thread is encouraging.
I think I'm about to run out the door to grab a new internal drive and start fresh.
2006 'Blackbook' Core Duo 2.0 ghz.
2 gig OWC RAM
10.5.8
PT Mpowered 8.04, Logic 9.1.1
Waves SSL,Omnisphere,Korg Legacy Digital
Absynth 4, EZ Drummer
Project Mix I/O w/ Black Lion Mod
Axiom 61,25, Korg Nano Pad
Leopard to snow leopard clean or update install joji Pro Tools TDM Systems (Mac) 10 01-01-2011 02:21 PM
Couldn't get snow leopard install to stabilize from leopard clone update! crizdee Pro Tools TDM Systems (Mac) 2 01-11-2010 04:45 PM
Native Instruments Akoustik & Elektrik Piano Compatibility on Leopard & Snow Leopard DigiTechSupt Virtual Instruments 0 01-07-2010 11:08 AM
Pro Tools 8.0.3 Updates for Snow Leopard & Leopard Avid Pro Tools M-Powered (Mac) 0 12-15-2009 07:11 PM
If buying Imac and MBox2 tomorrow: Leopard or Snow Leopard? Jairo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 11-22-2009 03:13 PM
