Old 02-05-2002, 08:28 AM
Styles Bitchly Styles Bitchly is offline
Default Meters move, but there\'s no sound!
Hey folks, has anyone run across this problem? While monitoring tracks everything is working fine, but occasionally I'll hit the space bar to stop playback and I get a very loud pop through my monitors. When I hit play to resume I see meter movement, but no audio. I can only resume listening by closing the session, and reopening, and sometimes I get a repeat of the same problem. Any ideas?
Due to budget cuts the light at the end of the tunnel will be turned off until further notice.
http://www.gidakdigital.com
Old 02-05-2002, 09:40 AM
Nine Spine Nine Spine is offline
Default Re: Meters move, but there\'s no sound!
Do a search on the DUC... a lot of people (including myself), have come across this one. There was never a solution (from Digi) found but if you save the session, close it, then re-open it your audio comes back after another loud pop (turn your monitors down...something you probably already figured out). Search for "Pops then no audio" or something like that. There have been many posts.
I.B.S. Studios
Old 02-05-2002, 11:06 AM
staylor staylor is offline
Are you by chance running any Waves plug-ins when this happens?
Old 02-05-2002, 11:19 AM
Staylor - I think you are thinking of the other problem "Exploding sound" that was found to be a problem with waves. This one is different but similar. Either way they both suck! One just has an actual fix from Digi the other does not.
Happy Hunting [img]images/icons/smile.gif[/img]
I.B.S. Studios
Old 02-06-2002, 12:49 AM
I'm not running any Waves stuff when this happens; however, now that you mention it, I believe it is only happening when I'm using the 001 limiter on the master fader. I can't remember it happening any other time. That's curious!
Old 02-06-2002, 07:28 AM
DigiTechSupt's Avatar
Here's a link that deals with this issue:
http://duc.digidesign.com/cgi-bin/ub...&f=24&t=006775
It is interesting regarding the presence of a DigiRack Limiter on the Master Fader. Keep this in mind when running other sessions and see if you can consistently reproduce this behavior...this would really help in trying to eliminate this problem.
Brent
Avid Audio Tech Support
Support FAQ
Old 02-06-2002, 08:11 AM
Just wanted to let everyone know that I have been consistently getting this since I bought my system and I don't have any plugins anywhere when it happens. No limiter no nothin'. I, however, have not pulled all of my plugins from the plugin folder and tried it though so I will try this next.
I.B.S. Studios
files make no sound and don't move meters when played in Pro Tools le StevenR Pro Tools 10 6 09-11-2013 11:41 AM
Pullin my hair out. No sound/VU meters in PT lspaulsp Eleven Rack 4 06-24-2013 09:04 AM
hybrid xpand no meters no sound *DELETED* Greene Virtual Instruments 1 02-02-2008 04:51 PM
Sampletank, meters but no sound Adman44 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 12 07-08-2005 11:42 AM
meters move super slow Blue Eyed Christ 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 07-05-2000 11:40 PM
