Old 01-22-2009, 08:48 AM
AudioPostChris AudioPostChris is offline
Default Plug-ins Preset Problem, Help!
I can't figure how to re-link all my factory presets to all my plug-ins, they somehow are no longer in the plug-ins settings menu? Can anyone help? The plug-ins are all in plug-ins settings folder.
OS10.5.5
PT HD 2
7.4
Old 01-22-2009, 09:13 AM
Default Re: Plug-ins Preset Problem, Help!
OS10.5.5
PT HD 2
7.4[/QUOTE]
Trashed DAE Pref, it solved the problem!
Old 01-26-2009, 09:39 PM
Jeff E Jeff E is offline
WOw.. this just happened here too... any one have a resolution on this?
Thanks
Jeff
Old 01-26-2009, 11:35 PM
maxpidgee maxpidgee is offline
OS10.5.5
PT HD 2
7.4
Trashed DAE Pref, it solved the problem![/QUOTE]
uh, read above
Old 01-27-2009, 07:57 AM
crizdee's Avatar
crizdee crizdee is offline
Thanks
Jeff
An easier solution than trashing your prefs and loosing all your settings is to simply open a plugin go to the presets menu and go to set root folder and direct it to your plugin presets folder library/app support/digidesign/pro tools/plugin presets. that should do it.
you might need to find the settings for the specific plugin you have open. the rest should follow automatically.
Chris
Producer, Engineer,
www.ukmastering.com
Old 01-27-2009, 08:33 AM
Oops... didnt read the last part of the 2nd post. Besides, that did nothing for this situation.
What I did figure out is that the setting of the root folder is universal for plugins. Some one had set the root folder for 1 plugin to a particular folder of said plugin and it affected all the plugs. Hmmm too bad I cant turn that feature off so that people who like to explore settings can't start clicking around..
Well at least I learned something new.
Jeff
Automate Plug In Preset Changes TwoPort Tips & Tricks 2 04-22-2009 08:45 PM
Plug in Preset Website? andydadd Pro Tools TDM Systems (Mac) 2 12-22-2005 04:32 PM
waves plug ins preset menu richsorr 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 07-29-2005 03:01 PM
Plug in preset question Ang1970 General Discussion 3 11-12-2000 11:34 AM
Plug-in Preset Location Jumpthis Pro Tools TDM Systems (Mac) 2 03-23-2000 12:00 AM
