Old 06-27-2006, 08:08 PM
OMAR3000 OMAR3000 is offline
Default USB MIDI KORG KONTROL 49 AND PADS
I HAVE THE KORG KONTROL 49 AND PADS AND I CANT GET IT TO WORK WITH PROTOOLS 7.1.. I BEEN TRING ALL DAY .. AND SECOND WHEN I PAY THE KEYS ON A MIDI TRACK I CANT HEAR IT BUT ONLY ON PLAY BACK ONLY CVAN ANY ONE HELP ME....
THANKS IN ADVANCE OMAR B
Old 06-28-2006, 06:12 AM
spkguitar's Avatar
Default Re: USB MIDI KORG KONTROL 49 AND PADS
First, please STOP SHOUTING!
Next, for your problem of only being able to hear it during playback, turn on MIDI thru (Options->MIDI Thru).
For the Korg, are you sure that you installed the korg drivers properly? If it is, then using "All" as the input for your MIDI track, or the MIDI input of your instrument track should work. It should also appear as an option on the MIDI input dropdowns (if it is installed properly).
It's only a controller, so there is not a lot of setup that you have to do.
Help setting up Korg Pad Kontrol (Not much experience with MIDI) rockguitarist1255 Pro Tools 10 1 07-20-2012 09:14 PM
Korg Nano Kontrol w/ PT 9 - HELP! kmcconkey92 MIDI 2 01-01-2012 11:41 PM
Korg Kontrol 49 m_atrix13 MIDI 1 10-04-2009 11:08 AM
Korg Kontrol 49 ajordon 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 05-28-2008 08:23 AM
Novation SL V Korg Kontrol (dum, dum, dum...) whunt MIDI 11 11-22-2007 07:54 AM
