Old 11-06-2004, 04:18 AM
TCDet TCDet is offline
Default MIDI I/O -All cables remove for reset?
Hello.
I have one Digidesign MIDI I/O running with an HD3a, Mac MD Dual 1Ghz system.
About once a week it stops responding.
Reset on the front panel doesn't work nor does rescanning from the Mac AMS setup window. Pulling the power and USB cables then re-powering also does not work.
The only way to reset is to literally pull all inputs and outputs while the unit is off, turn it on the re-connect all inputs and outputs. Works fine for a few days then gets buggy again eventually within the week it stops communicating (In and Out) the remedy above then needs to be repeated.
Connected are: Mackie D8B, Roland 200 controller, Roland JX8P, Kurzweil 88, Kawai Midi acoustic grand.
PS The Digi web link for MIDI I/O 2.1 or 2.0.3 software installers is unavailable. (Tried both Safari and i.e. to access((forbidden, not enough permissions)))
(This system is 1 of 2. The other system is using 2- MOTU MTP-AV, USB & Serial-networked 2nd unit. All running fine in 6.4 and now in 6.7)
OS 10.3.4, PT's 6.4 CSx
Not sure of the MIDI I/O soft/firmware. (Bought this in July 2004)
Thank you.
reset midi or entire I/O Xray55 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 01-23-2008 09:48 AM
MIDI I?O Reset This is soooo annoying! Touchwood Studios Pro Tools TDM Systems (Mac) 0 09-17-2007 07:32 PM
MIDI (USB) reset ? stevegalante Pro Tools TDM Systems (Mac) 4 02-15-2004 06:24 AM
Any way to REMOVE or reset authorization? Brian Barry 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 02-20-2003 08:36 AM
Reset on midi faders flytrap MIDI 0 06-20-2001 05:12 AM
