1 IDE and 1 SATA HD
Given 1 IDE and 1 SATA harddrive, which would be better suited for the OS and ProTools install, and which would be better for the ProTools audio files (all other factors being equal)?
Thanks, Mike. |
Re: 1 IDE and 1 SATA HD
Assuming the same speed and cache, I doubt it makes any difference. I have used both and in every combination and all work fine. Right now, I use an IDE drive for system and have 3 SATA drives in a triple drive cage setup where the drives can be removed anytime(after they are stopped under Safely Remove Hardware). No caddies or tools required so its quite handy. My only suggestion would be to use the smaller for system(if they are not the same capacity). I doubt I will buy any more IDE drives.
G5 Dual 2.7GHZ - Sata I or Sata II Drive setting ? | toneski | Pro Tools TDM Systems (Mac) | 4 | 05-06-2008 12:18 PM |
PT and SATA HD | studio rec | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 03-13-2006 09:24 AM |
Do SATA Controllers/ PCI Cards/ SATA Drives work.. | Jason Robo | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 06-14-2005 07:23 PM |
Onboard SATA + PCI SATA + Protools LE = bootcrash? | insolace | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 04-10-2005 11:06 AM |
SATA vs ATA? | MadeByNick | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 12 | 04-09-2003 06:19 PM |
