  #41
Old 12-04-2021, 03:41 AM
dcoffset dcoffset is offline
Default Re: Monterey is now available
Just to confirm the following plugins from the Avid bundle are causing PT to hang on load (plugin scan):
BF-2A.aaxplugin
BF-3A.aaxplugin
Eleven MKII.aaxplugin
Fairchild660.aaxplugin
Fairchild670.aaxplugin
moogerfooger AD.aaxplugin
moogerfooger LP.aaxplugin
moogerfooger Ph.aaxplugin
moogerfooger RM.aaxplugin
ProCompressor.aaxplugin
ProExpander.aaxplugin
ProLimiter.aaxplugin
ProMultibandDynamics.aaxplugin
ProSubharmonic.aaxplugin
Purple Audio MC77.aaxplugin
ReelTapeDelay.aaxplugin
ReelTapeFlanger.aaxplugin
ReelTapeSaturation.aaxplugin
ReVibeII.aaxplugin
SoundReplacer.aaxplugin
Space.aaxplugin
Tel-Ray Delay.aaxplugin
Voce Chorus-Vibrato.aaxplugin
Voce Spin.aaxplugin
X-Form.aaxplugin
Test system:
M1 Max, 16-inch, 64gb
OSX Monterey 12.0.1
PT 2021.10
Studio: Mac Pro | OSX Monterey | PT 2023.9 HDX | DAD AX32
Remote: Macbook Pro | OSX Ventura | PT 2023.9 Ultimate | UAD X8
  #42
Old 12-04-2021, 03:44 AM
That would be Complete Plug-In Bundle, which is (as is PT itself) not supported on Monterey and/or Apple Silicon. Sit tight, I am hoping santa brings us a christmas present. Every year since Avid went to year.month versioning, we have had a x.12 release.
  #43
Old 12-07-2021, 02:55 AM
hagybear hagybear is offline
Ive tested monterey on my mac book pro 2021 max pro
With protools 2021.10
Plugins not working :
Izotope
Reason rack plugin
Metric halo
They work with logic and ableton
  #44
Old 12-07-2021, 03:10 AM
Izotope
Reason rack plugin
Metric halo
Known problem, and PT/iLok are not yet Apple Silicon native so this is not surprising
  #45
Old 12-08-2021, 08:13 AM
GSF GSF is offline
I wish I would have seen your list yesterday, I just arrived at the same conclusion...the hard way!
BF-2A.aaxplugin
BF-3A.aaxplugin
ReVibeII.aaxplugin
Space.aaxplugin
Voce Spin.aaxplugin
X-Form.aaxplugin
Test system:
OSX Monterey 12.0.1
PT 2021.10
  #46
Old 12-08-2021, 09:24 AM
2021.12 released without Monterey support, please update and see if it fixes anything
  #47
Old 12-08-2021, 10:57 AM
off the wall's Avatar
Avid added a dialog on PT launch that warns that the plugins are not compatible with Monterey and offers to move them to the Unused folder, rather than PT just crashing.
File Type: jpg Screen Shot 2021-12-08 at 1.45.35 PM.jpg (25.0 KB, 0 views)
offthewallproductions
  #48
Old 12-08-2021, 04:37 PM
Eric Lambert's Avatar
BF-2A.aaxplugin
X-Form.aaxplugin
Test system:
OSX Monterey 12.0.1
PT 2021.10
Thankfully, those are all plugins I've not used in a very long time and won't miss one iota. Unfortunately, there are others I *do* use which seem to be problematic according to some people.
Thankfully once more, I have no reason to upgrade to Monterey yet. For those who are forced to use Monterey, I hope these hurdles aren't too difficult.
  #49
Old 12-09-2021, 04:32 AM
I'm presently running Monterey 12.1 Release Candidate, and it seems to have fixed some of the uglier problems with 12.0.1, most notably the memory leaks, so the general release should be out for everyone in a week or two (unless they have another RC).
The fundamental issues with Avid Complete Bundle are not altered however, and I suspect Avid will have to recode some of that stuff to make it work.
PT itself seems pretty stable on 12.1RC in my limited testing. And I have EUCON working now too. So, along with the 2021.12 build, we are slowly converging on some workable solutions. But I'm still guessing that it will be nearly a year before it's a solid platform for commercial use. After all, there are bound to be some hiccups when iLok and PT go AS native.
Dominic
  #50
Old 12-09-2021, 10:06 AM
Obsidian Dragon Obsidian Dragon is online now
Good to hear that the memory leaks are fixed in the 12.1 release candidate. Earlier posts online did not mention the memory lead fix so there was general concern. As you mentioned, we are getting closer with Monterey and Apple silicon for Protools, but not there yet.
Obsidian Dragon
Mac Studio M1Max - 64GB
Has anyone tried Pro Tools 2021.7 on the Monterey Betas? off the wall macOS 28 11-17-2021 10:21 AM
