Old 01-24-2022, 12:20 AM
Schottlandru Schottlandru is offline
Default Locan Expand -> not working?
Hello there,
I am not sure if my issue is a bug or due to the new custom faders maps available.
A studio I freelance at seems to have updated Eucon since one of my last mixes there.
Back then I used to be able to hold EXP to have local expand faders to work.
The faders would jump to -inf and then Attention+EXP allowed me to map plugin parameters for example.
IIRC, now the custom map would be created via the master module "Custom" features, touch parameter and fader there - is that correct? Or is the old way of knob-to-fader mapping still available?
My main issue though: Pressing and holding EXP doesn't switch the faders in local expand mode.
I get them to jump down if I define an Expand fader zone (which I don't need) and have auto-expand enabled, however as I want to temporarily switch faders to expand mode I prefer the press-and-hold method.
The LED color on the EXP button changes between red and blue (or purple, I cannot remember), but the faders remain volume mix faders.
Anything I am missing? Do I need to create a map first, before the faders actually switch? (But then why does auto-expand work with a dedicated expand-fader-module and swith to -inf?)
Or maybe a bug?
Thanks for any ideas!!
Andrew
Old 01-24-2022, 05:54 AM
creativecontrol's Avatar
Default Re: Locan Expand -> not working?
Greetings,
Legacy versions of S4 S6 used a different method for programming expand faders -> Attention + Exp, then the association as you mentioned from knob to fader.
Current versions of S4 S6 create, modify and manage all knob and fader maps from the Master Module as described on page 115 here ->
https://www.dropbox.com/s/qbdz33gb94...21.10.pdf?dl=0
Fader maps must first be created before they can be accessed. Legacy Fader maps will not open on current S4 S6 systems - so they need to be recreated using the process described from the Master Module.
best,
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Old 01-24-2022, 06:07 AM
Thanks Jeff for the quick reply - I will work my way into defining new maps then.
However what struck me - the map needs to be created first, for the local fader expand to actually activate? Is that correct?
I thought there might have been default maps or even just an "empty" map moving to the faders when holding EXP?
(I found a post with a similar issue that seemed to be linked to IP addresses and such).
Will try mapping next time, it would be great to have confirmed that the fader unit was working as expected though?
Thanks!
Old 01-24-2022, 06:10 AM
While there are default Knob maps (expanded and non-expanded), there are no default Fader Maps, either legacy or current.
best,
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Virtual Instruments Working, except Expand johnosmusic macOS 0 07-17-2012 09:38 AM
arpeggiator not working in expand Monaco 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 06-07-2009 02:40 PM
Expand UI bug? mcpissto1 Pro Tools M-Powered (Mac) 4 07-31-2008 01:31 PM
What are you using to expand your 003 I/O? poaprex 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 12 05-31-2008 09:48 AM
Expand tracks - Not working with correct meta-data Frank Kruse Post - Surround - Video 11 11-12-2007 08:50 AM
