Inconsistent Click Track
Hello All,
I have not run into this problem before, but today when trying to make a click track, I am getting an inconsistent beat. Not sure what is causing this. It does a few beats, not evenly, then drops out, then goes to a double time beat, then slows back down again. If I move my playback marker, it does the same pattern again. I closed the session, created a new session, and am getting the same results! I've tried turning everything off and starting from scratch again, but nothing is wiping out that pattern. I thought it might be a clocking issue, but it is getting the clock from it's internal source. I do have a Motif 8 connected to Protools through a MIDI cable, but it has never caused me problems in the past. Any suggestions as to what else to try to remedy this would be greatly appreciated! Rob |
Re: Inconsistent Click Track
Nick
Core i7 920 OC'ed @ 4.0 GHz (200 X 20) 12 GB Patriot Viper Extreme Asus P6T OCZ Agility 64 GB SSD Hitachi 1TB 32 MB HDD WD Caviar Black 500GB Saphhire HD 5850 3 x 20" monitors Eleven Rack w/ ERXP Fender Super Champ XD Marshall JCM2000 DSL100 Silver Edition W/ Silver Jubilee Cabinet |
I ran into this issue MANY years ago when I was still on a PC and it seems to me the solution was as simple as changing the buffer size, I can't recall whether it was higher or lower. I would mess with that and it's always a good call to try trashing the preferences and restarting :)
----I was thinking of taking a solo in the bridge. -Nah, I don't think that would sound good. ----Ok, well how about just a series of cool riffs? Mac Pro 2008 (Harpertown) -- OS X 10.8.2 -- 16GB RAM -- WD Black Drives -- UA Apollo Quad -- Pro Tools 10 w/ CPTK |
Thanks for the tips. I did check the tempo map, and it is just a single tempo. I will play with the buffer size and see if that fixes it. One more thing...I needed to find a work around to get a click, and I used BOOM and deleted a pattern, made a 4 beat click, and that stays consistent, however, the Digidesign click does not.
Very strange! |
In the Click/Countoff Options try changing the duration for accented and unaccented notes to a different value - start with 10 and move up from there if it still behaves oddly.
Avid can you please sort out the click track & Click 2 plugin | protoolsuserman | Pro Tools 11 | 14 | 11-14-2013 08:11 AM |
Inconsistent tempo when setting up a click track in PT? | [email protected] | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 01-03-2009 12:21 PM |
Getting the click track to click at 16th notes... | broken81 | Tips & Tricks | 1 | 06-27-2008 07:06 PM |
Click Track - How to "UN" accent the click plugin | pepperbox | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 11-02-2006 06:37 AM |
Inconsistent group right-click behavior | BGee | Pro Tools TDM Systems (Mac) | 0 | 09-22-2006 06:05 PM |
