drum triggers and sampled drum sounds
A friend of mine has drum triggers and an alesis D4 drum brain. I was wondering if it was possible to assign drum triggers to seperate midi channels and then create a midi channel in pro tools and assign that pad to a track. So then I would have 8 tracks of drums recorded as midi tracks. Then I want to know if I can replace the sounds with sampled sounds (say if I did not like the snare sound recorded from the D4 I could replace it with a sample that I liked in pro tools). Is this a common practice? would it even work? any response would be much appreciated.
Re: drum triggers and sampled drum sounds
nice name
i usually do them all on one track, then use the split note function, only takes a couple of minutes to copy all F#2's to another track. Then you can grab them all and move them to the right sampler note. works for me anywho jimmy |
Drum Triggers | costas.themis | The Drum Room | 2 | 01-25-2012 03:12 PM |
MIDI Drum Triggers | vjk | Pro Tools M-Powered (Win) | 2 | 07-13-2007 11:33 PM |
drum triggers?? | bluesguy | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 11-17-2005 07:37 PM |
drum triggers | MarkPresti | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 11-10-2005 09:30 AM |
drum triggers/modules | ROOM 12 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 15 | 09-25-2001 12:25 AM |
