Pro Tools wont bounce anything on my G5
Just tried to start work again on my home computer (1.8 dual G5) not one thing will bounce down. Trying to bounce Kontakt 3.5 tracks down. Decided to make Kontakt inactive. The other audio parts without kontakt will not bounce, disabled nearly all plugins only using 5% of the cpu. All bounces crackle then fail. Have tried to follow all the troubleshooting advice on the forums but nothing seems to work.
Anyone one having the same problem? |
Re: Pro Tools wont bounce anything on my G5
specs G5 dual 1.8, 4GB ram, 10,000 rpm boot drive, digi 002 rack, PT 8.0.1cs1
1.8 dual G5 4GB ram 10,000 rpm boot drive. Digi 002 Rack, Pro Tools 8.01cs1 |
Just tried a bounce with nothing but the signal generator in the session, failed!
Keep getting the "Increase Hard Ware buffer size" error message, will a new intel based mac fix this or could it be the sound card (002r)
How about trying a few things and seeing if you can get some joy. 1) Use the Pro Tools Tech Support Folder , which has tools and utilities to assist in diagnosing and troubleshooting potential problems you may encounter, including a plug-in version generator which can be useful when verifying plug-in compatibility. http://www.digidesign.com/index.cfm?...4&itemid=25974 2) Try this little cheeky http://web.mac.com/jcdeshaies/Delete...Bienvenue.html which will also delete a few bits and bobs. 3) Try opening or beginning a session using your internal (SATA) drive and see if this makes a difference. 4) Defrag external audio drive (with program like 'Drive Genius) or drag all files off the audio drive, format the drive and then drag all the files back on. If the audio drive is 'messy' it can cause lags etc. 5) Try Bouncing after setting the number of Processors to '1' rather than '2' to see if this makes a difference. Some plugins don't run so well on 2 processors and sometimes can cause unusual behaviour. 6) Check to see if your buffer size is set low or high? Try setting to 2048 and see if that makes a difference? 7) Drag the entire contents of the Used plugins folder in to the unused folder, re-boot PT and try to bounce something without Plugins and see what happens. If it's the same then the plugins are fine, and you can drag them all back in to the used folder - if the song bounces, then perhaps a dodgy plugin is causing problems. You can add the plugins back a few at a time and try to pin point which one is dodgy. 8) Check your OS for updates. Leopard 10.5.8?? 9) Try different Firewire cables / ports 10) Ask Digidesign to release a stable version of PT8 for PPC users before stopping support for them. All the Best.
Hack Pro (4.2Ghz i7 Quad/16GB) PT11 / OSX 10.8.5 TC Electronic Konnekt 24D |
thanks, have tried most of that, dual G5 only allows 1024 buffer size as the highest. Will try to clean up my audio drive and use the program you suggested.
Thanks Jazzy J, the reformatting of my record drive helped with the bounce, however pro tools is still buggy. I really hope they give us G5 users the update.
M-Powered 8 wont bounce video | Jamesstown | Pro Tools M-Powered (Win) | 0 | 05-09-2011 02:18 PM |
Pro Tools 6.4 Digi 001 WONT (Bounce Down) !!!! | jcassar313 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 05-09-2007 08:52 AM |
help wont bounce to disk | michael london | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 10-27-2006 11:21 PM |
PT free wont bounce (but it does boogie) | Diggers | Digidesign Hardware & Software | 1 | 03-04-2003 02:57 AM |
5.1 wont bounce. Says "bounce handler cant keep up try convert after bounce...." | Trash Man | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 9 | 05-21-2001 08:28 PM |
