Old 01-10-2022, 10:10 AM
Cayce Cayce is offline
Default Erratic MIDI Behavior Needs to STOP!
Working on a complex session where the MIDI piano composition was causing CPU overloads, I finally had to create a new session with only that single MIDI piano track so that I could get the work done, then migrate my work back into the main session. Even in that isolated session, though, PT is incapable of allowing me to build this MIDI piano track without trashing my workflow.
In trying to patch in a 2-measure section, one attempt plays the piano sustains as they're supposed be, on both the pre-roll and the recording. On the next attempt, all pedal sustains are gone and notes aren't following the tempo.
With no other tracks or plugins to interfere with resources to manage this single MIDI track, what could causing this (other than the common knowledge of PT being garbage)?
Thanks.
Pro Tools Studio, 2023.3.0
Mac OS: Ventura 13.4
System: Mac Studio 2023, Apple M2 Ultra, 128GB Unified Memory
2TB Internal SSD
Apple Studio Monitor, 27"
3 External Monitors: 27", 27" & 65"
Apollo X8P Mixer Interface
PreSonus 32R Mixer Interface
Old 01-11-2022, 04:32 AM
musicman691 musicman691 is online now
Default Re: Erratic MIDI Behavior Needs to STOP!
And make sure PT isn't blocking any MIDI messages from being recorded.
What VI is providing the piano sounds?
How about the rest of your specs like OSX version and PT version? I do see a big problem right in the OP's sig file and that's that Fusion system drive. Those things are a big no-no for any kind of audio work especially PT. Some Fusion drives use a 5400 rpm spinner for their big storage.
Jack
QAPLA!
Old 01-11-2022, 05:29 AM
Stephen Bond's Avatar
Stephen Bond Stephen Bond is offline
I'm finding MIDI playback with the latest Pro Tools can be a bit erratic on the M1. When the CPU load rises, MIDI playback seems to stop on occasions. Audio will play AOK but MIDI playback is missing. Stop and restart once or several times and it reappears. This is independent of the VI. I have the same issue with both NI Drummer plugins and the AIR Mini Grand
Anyone else found similar behaviour?
Stephen
Mac mini M1 2020 16Gb Memory- 256Gb Storage, Monterey, Pro Tools 2022.9, Focusrite Scarlett 2i2
https://www.waves.com/r/djgsi6
Erratic behavior in groups bin Ben Jenssen Pro Tools 2020 2 08-03-2021 05:56 PM
Delay Compensation erratic behavior wyman macOS 11 10-13-2017 05:50 PM
Erratic Delay Compensation behavior (bug). The Dubnicks Pro Tools 9 0 12-05-2010 09:16 AM
LE 6.0.1 introduces erratic midi behavior LSRdigital 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 04-06-2003 11:17 AM
Automation erratic behavior nubus system Cabin Studios General Discussion 0 01-05-2001 09:22 AM
