#31
Re: This is AWESOME | $290 4 Slot PCIe to PCI Expansion Chassis
Anyone have a conclusion to this German find?
#32
Bump.
#33
#34
i'm about to try in a few days without the powermod....
I've only got HD1 though.
Mac Pro 8-core 2.8GHz Pro Tools 10 HD |
#35
#36
#37
Jantzen- Any success?
#38
http://www.virtuavia.eu/shop/full-pa...-atx-case.html
It now works with the new improved power supply. |
#39
http://www.virtuavia.eu/shop/full-pa...-atx-case.html If it does, all my problems are solved.
Brian Steckler, Producer |
#40
I have a HD2 system hooked-up to my 2.8 Ghz 8 core MacPro and working with the Virtua Via PCI-E to PCI expansion system.
I am sure the Magma 2000.00 solution provides better performance/stability, but for $200.00 I could not pass up this experiment. The highest and most DSP dense voice setting that I could get out of this rig is: 96 voices 2dsp's @44.1k. Be prepared for a lot of Kernel panics(well why not this computer has hardly broken a sweat since I forked over the $3000.00 a year ago!) I have been trying to max this configuration out and usually the result is a nifty Kernel panic directly relating to arguments about the AppleI/O Kit pci something or other. Have the Protools prefs trasher ready and waiting until you can figure out how far you can push this deal. It seems that Protools 8 works a lot better with this rig than did 7.4.2. I am considering the 1500.00 Magma board set route when I have the cash. I have done a fair amount of googling regarding PCI-E and PCI HBA's,Backplanes,Backaches, headaches, you name it.... and my instinct is that the Magma system is 'tuned/optimized' to get the most out of this essentially stop-gap soultion for the lagging(not able to develop as fast as the World Mass-Market-Driven computer industry) audio hardware companies and developers. But until then I am totally stoked because with a minimal investment I can marry my PCI HD-2 rig with the speed and power of my new MacPro! This way I can save my pennies for whatever DIGI has up their sleeve in new TDM hardware land... I actually can hardly wait, other than the bleeding of money that will ensue! One big plus with the Virtua Via rig is that the pci slots are 32 bit(they are actually shorter than the HD cards) and my UAD-1 cards don't like 64 bit pci slots, like the ones that are in the Magma Pe6R4! So I can use my UAD-1 with my MacPro as well! AL p.s. if you are really technically Saavy Cooldrives has the little 4 slot box for 200.00 where VirtuaVia wants 274.00 plus shipping for the same box! Rohs makes the desoldering quite tricky so don't mess around if you are not really good at soldering! |
FS: HD2 PCI-x in a Magma 2-slot chassis with PCIe card | Justin1524 | Buy & Sell | 5 | 11-29-2013 01:09 PM |
OWC announces 4 slot PCIe to Thunderbolt Chassis | nst7 | Pro Tools 10 | 4 | 04-17-2012 11:41 AM |
SBS 7-Slot Expansion 32-bit Chassis & PT 6/ G5 | Mt.Everest | Pro Tools TDM Systems (Mac) | 3 | 03-11-2004 01:21 PM |
Slot Order for AVOption/5-Slot Mac & Expansion Chassis | Samhein | Pro Tools TDM Systems (Mac) | 0 | 05-01-2001 09:40 AM |
SBS 13-Slot Expansion Chassis | Dirk Buro | General Discussion | 4 | 08-30-2000 08:57 AM |
