#41
Re: HDX smokes HD2
Pro Tools has always buffered a very small amount of data to ram while writing to disk but I think it's way less than a meg. Disk cache is actually caching audio that is first on the timeline in pro tools (that's why there's a timeline cache meter) then it caches the rest of the audio in the session (disc cache meter). It's for playback of audio. But to your point - that alone takes a huge load off of your drive(s) for recording audio so your performance should far exceed anything prior to this disk cache feature. |
#42
Re: HDX smokes HD2
NewdestinyX,
I don't recall ever seeing an ad in which Digi suggested that TDM sounded better, unless they were talking about the whole system in general. Obviously the HD interfaces sounded better than the LE ones, so they may have been pointing that out. But I could be wrong. I don't claim to have seen every ad or statement they ever ran. I just don't recall seeing it myself. In addition, whenever I would ask that question to the rep or salesman of a plugin manufacturer, such as Waves or McDsp, they plainly stated that the plugins sound identical. However, as mentioned, certain users stated that they did sound better, at least to their ears. |
#43
Re: HDX smokes HD2
no it doesnt
#44
Rig 1-Mix/Mast: PTHD 11.3.1; MacPro 6core (6,1) 3.5 GHz Xeon E5; 10.10.3 (SSD Drives for audio); Apogee DUET, FireStudio2626 as Hware Inserts to PT for outboard Rig 2-Cutting&Remotes: PTHD 11.3.1; MacBook Pro (8,1) 2.8 GHz Dual i7; 10.9.2 (128GB int '6G' SSD drive); Profire LightBridge (FW800), 32ch Presonus Digimax FS |
#45
Re: HDX smokes HD2
bassist...deep pocketz anyone???!!! The Basschakra Lucid Soul Trip i7 Builds - Specs and Results HDNative | Omni | i7-3930K OC'd 4.0GHZ | ASUS X79 Sabertooth | 32GB GSkill DDR3 2133 ram | mo' stuff |
#46
I also think Avid makes things very confusing by calling it "Disk" cache in the Playback Engine Dialog. Because there is such a thing as a true 'disk' cache which is entirely different than a ram disk cache. There's plenty of room to change the name to RAM Disk Cache.. It would be so much more descriptive.
#47
Re: HDX smokes HD2
....and Waves AAX is probably a year away.(How many hundreds of Plug ins do they need to code?) It is like when you get your new computer and you use it before you load anything on it. It smokes!!! It just shows how ridiculous we are. There are like 3 or 4 plugins available to work on a HDX card and people are bragging it up...lol You guys are like 2 years away from even using the cards fully. Right or Wrong????? So why so excited? You really have a over priced Native system. |
#48
But - it is what it is - and I guess it gives some people a sense of security that after spending multiple thousands of $ - they need to see evidence of 'its horsepower'. ;-)
#49
Re: HDX smokes HD2
Sure, after having spent that kind of money.. we all want to be sure to have done the right investment.. but..actually I'm using in real world... constructing right now and mixing some sessions I created using HD6... Converting the old tdm plugins in AAX dsp (obviously only a few.. but with channelstrip, revibe, all the softube eq/dynamics.. you can do it..)... and the general feeling is much more snappier than HD... Regarding VIs... I noticed a great improvement dealing with rtas plugins in general (like using 100 plugins and having only 11% of the cpu busy.. maybe Protools 10.1 using HDX hardware has more room for native CPU processing... i don't know.. ) I'm gonna try a test using more than 10 VIs... and post the results.. Regards. Michele
#50
Re: HDX smokes HD2
The Funny thing I will be able to run any session you run off my LapTop. I just installed Revibe 2, Impact and Reverb One on my Laptop. Beautiful!!!
Remember the old argument TDM or Native. I was on the TDM side now there is no difference. We can move on. I can't wait for the first AAX DSP is better than AAX Native Thread. lol I agree with you too. HDX is Mos Def better than TDM. I don't think you can even compare the two. I hope VI's do run better on your amazing system. They still choke on mine and my CPU will be at like 9% |
Edit Smoothing smokes on a G5! | bassmac | Pro Tools TDM Systems (Mac) | 0 | 02-03-2005 06:21 PM |
