Falcon crashes Pro Tools after crossgrade
Falcon crashes pro tools after cross grade .
Osx 11.6.1 PT22.5 |
Re: Falcon crashes Pro Tools after cross grade
Have you installed the latest version from the UVI Portal?
~Will |
Yes unfortunately i did and also did the falcon update that was suggested
Unfortunately I'm on OS 10.15.7 so I'm probably no help. But mine works with 2022.5 and .6
~Will |
Thank you, yes that's odd. It was working fine till the upgrade. I'm going to try to backtrack and reinstall the old one
Put the old Avid 2.5.3 works again with the cross grade ilock authorization.
I'm suspecting that the Avid sound library for falcon is not compatible |
I'm running PT 2022.7 - with Falcon 2.5.7 (crossgrade) - with no issues. The AVID soundbank loads fine. I use Windows 10 and macOS 10.15 fwiw.
Not sure how that helps you except to know that it *can* work.
2023 M2 Pro - MacBook Pro 16 -16GB RAM - 1TB SSD. 2021 Razer 14 Ryzen 9 5900HX - 16GB RAM - 1TB SSD. PT 2024.3 Native Life is like an Analogy. |
Thank you, it helps a lot to know that it works for you. Do you happen to remember if you did a de-install of 2.5.3 prior to installing 2.5.7 ?
When i did mine i just updated UVI portal and did the Falcon update directly. |
I did not uninstall, I used the Portal like you.
~Will |
Thanks Will, i'll try again and see if it works this time
Avid dropping Falcon PSA - crossgrade to full UVI version $100 includes $100 voucher | smurfyou | Virtual Instruments | 64 | 02-07-2023 06:42 AM |
new version of falcon crushing pro tools | [email protected] | Virtual Instruments | 3 | 01-10-2022 11:26 AM |
UVI Falcon in Pro Tools Trial? | KJMorgan | Getting Started | 5 | 12-12-2020 04:28 AM |
Falcon shuts down pro tools | Agonzo | General Discussion | 1 | 02-24-2020 08:34 AM |
UVI Workstation & Falcon included with Pro Tools | LightWing | Licensing & Accounts | 256 | 02-04-2019 09:40 PM |
