  #21
Old 08-17-2022, 02:22 PM
Eric Lambert's Avatar
Default Re: EuCon crashes overnight, every night
Originally Posted by EddieJones View Post
Can you first try with the tablet on.....then if it starts crashing again try running EuControl in Rosetta mode and report back. If it doesn't crash in Rosetta mode then we know of this issue.
I've kept the Fire tablet on for the past few days now and not experienced a crash. My other habits are the same: turning the monitor off regularly, keeping the iPad turned on (it's also running the Control app -- the Fire is piggybacked on top of the S1 whereas the iPad is configured as a 2nd device in EuControl).
The only thing that has changed recently is an OS update (to 12.5 from the previous version of Monterey) and last week Avid Link updated ProTools to a newer build of 2022.7.0.
  #22
Old 08-17-2022, 05:38 PM
EddieJones's Avatar
It could be OSX update then...they change a lot of things each release.
  #23
Old 08-17-2022, 05:45 PM
thebeatless thebeatless is offline
EuCon has been crashing for me since 2022.4. It happens all day and overnight. Like I've said before, Rosetta helps but it's still far from perfect. When I reach for a button or fader, there's a 50/50 chance that it will work. This is all since getting a Mac studio Ultra.https://duc.avid.com/images/smilies/mad.gif
  #24
Old 08-17-2022, 07:40 PM
EddieJones's Avatar
If it's that bad, then the logs will help. Please use the Collect logs option from the EuControl menu and upload them somewhere and send me a PM with link. Others(and our testers) do not see it like that, so there must be something else up on your system. I presume you have tried a full uninstall, reboot and reinstall, inc. checking remove all prefs?
Edit: If this all started since getting the Mac Studio.....did you do a migrate? This has known issues.
  #25
Old 08-20-2022, 12:46 PM
Eddie: I'd asked about this above but didn't see a response. Can you explain where the "Collect Logs" option is? For some reason I don't see it.
  #26
Old 08-20-2022, 05:46 PM
mattrixx mattrixx is offline
You can find the logs files at -->
Mac:
/Library/Logs/Avid/EuCon
EuControl.log
MC_Client.log
Pro Tools_EuCon.log
/Library/Logs/Avid/S6
WSControl.log
Win:
C:\Users\UserName\AppData\Local\Avid\Logs\S6
WSControl.log
C:\Users\UserName\AppData\Local\Avid\Logs\EUCON
ProTools_EuCon.log
MC_Client.log
EuControl.log
Matt McKenzie-Smith
mattrixx.net
SourceConnect - mattrixx
AVID Collab user - mattrixx
MacStudio Ultra / LogicProX / IzotopeRX10+ / SourceConnect / MelodyneStudio5 / WAVES Mercury / NI KompleteUltimate / ProToolsUltimate / RME UFX, UFXII, Babyface / AVID S3 + DOCK / Barefoot MM27 gen2 / Barefoot FP01
  #27
Old 08-20-2022, 08:00 PM
EddieJones's Avatar
Right click the EuControl notification icon to show its menu. Its one of the items.
  #28
Old 08-20-2022, 08:10 PM
Matt McKenzie-Smith
mattrixx.net
  #29
Old 08-22-2022, 03:02 PM
Silly me. I've looked at that menu 1,000 times and (apparently) never noticed that function. Thanks!
  #30
Old 08-22-2022, 03:03 PM
I have to say though... I've still not had a EuCon crash since upgrading the OS to 12.5.1. Seems that that took care of whatever was causing the issue.
Fire tablet goes offline overnight, every night Eric Lambert Avid S1, S3, Dock and Control App 8 10-22-2020 11:45 AM
Powering off S3 crashes Eucon ulisauer Avid S1, S3, Dock and Control App 12 10-22-2019 07:59 AM
Eucon crashes planck Avid Pro Mixing General Discussion 23 09-14-2018 09:20 AM
Cubase Crashes from EUCON aptmusic9 Artist Series 0 06-05-2014 08:40 PM
eucon 3.0 crashes tandri79 Artist Series 7 06-24-2013 01:24 PM
