Old 08-25-2023, 12:34 PM
TheMightyQuinn TheMightyQuinn is offline
Default Piano roll focus / scriolling
Hello,
Are there any settings, key commands to center the notes, or options I'm missing where I can set how mouse operations act when manipulating where in the view the MIDI notes are displayed?
For example, when notes are outside of the current piano roll view (too high or too low) and then trying to better focus the MIDI notes on a piano roll (centering the notes, for example), pulling the piano roll up or down moves the entire roll way too fast for my reaction often resulting in the notes moving too for up or down on the piano roll then requiring more up and down gyrations. Often I'm forced to expand the piano roll view, but while that does work, it slows down the workflow for me.
Hope fully explaining this clearly. Any thoughts?
TIA,
Greg
Apple Mac Studio M2 MAX, 10 core, 96Gb RAM, 1Tb HD, macOS Ventura 13.4, Pro Tools 2024.3, AVID Omni HD, 2x AVID I/O, 1x HDX, Sonnet Tech Echo Express III-D (Thunderbolt 3 Edition), UAD-2 OCTO PCIe.
Old 09-05-2023, 05:28 PM
take77
Guest
Posts: n/a
Default Re: Piano roll focus / scriolling
Sorry for the late reply. Not sure if you figured it out since posting but maybe this is the shortcut you're looking for:
Select the notes you want to edit and press Opt + F.
Selection now in focus.
Xpand! on piano roll? kemikalgeneral Getting Started 4 10-04-2021 02:45 PM
Tiny piano roll nyjdams macOS 5 12-03-2017 01:48 PM
piano roll / keyboard SupreGlu Pro Tools 10 4 10-28-2015 10:10 AM
Problem with VST sounds when using piano roll Callum_Flanagan Pro Tools 12 2 08-29-2015 12:57 PM
Piano Roll ? cubs Pro Tools 10 1 01-01-2013 05:49 PM
