Since PT 6, pressing PLAY only works sometimes!
Ok...
Anyone else have this problem? Since I upgraded to PT 6, I have to press play or space bar or the #3 a bunch of times to get the machine to roll. Three out of four times I press those buttons, nothing happens. This is INCREDIBLY frustrating when I'm in my performance-brain-mode at my synth and I'm about perform the mack-daddy take and I have to sit there pressing the button. Now...I'm not running the fastest system in the world. Pentium III, 933mghz, 512, Windows XP Any suggestions here? Thanks! -todd amodeo http://bartlebymusic.com
https://soundcloud.com/user-496684376 |
Re: Since PT 6, pressing PLAY only works sometimes!
lower your DAE playback buffer to 2 and see if it helps. If you have big samples loaded from a sampler, this will slow the response time for playback. I am experimenting with more RAM and a separate audio drive to see if this helps.
Cliff Stendel -iMac 5K 32g
-PT12. HDX -HD I/O 8x8x8. -HD Omni -Avid S3 -API 2500 -API 5500 -UA 2-1176 -UA 2-610 -Neve 1073, Chandler LTD-1 -Eventide H8000FW -Lexicon PCM96 -Bricasti M7. -Joe Meek channel. -Waves Mercury, Flux all, Softube All, Plugin Alliance all, McDSP all, Sonnox All, MH production, Wave Arts,a bunch more -Moog Voyager XL, Nord Piano, Hartmann Neuron, ARP Axxe, Gibson Les Paul, Mesa Boogie Roadster, Kemper, Taylor T5 and T5-12 |
I had the same thing, and I was told that if you go into setup/preferences/and operations (I believe), you need to set "record allocation" to something like 10 minutes, instead of 60 or unlimited like it defaults to. That helped quite a bit.....it didnt' get rid of it, but helped.
I have found that this problem on my 002r is related to the buffer setting. The same thing happens to me if the buffer is set to 64. I just move it up to 128 and I am fine. I would try a higher buffer setting to see if it works for you.
John-Q6600,GA-EP35-DS3P, Zigmatec S1283: 235 D-Verbs @ 2.4 ghz |
Thanks for all the tips DUC-ies!
I'll try 'em out and hopefully get some relief! -todd
PT HD 10.3.5 Accel 4 x3 192 I/Os (48 in 24 out Analog) Sync I/O Big Ben Control 24 |
Sorry to report that the above suggestions
have not really helped my problem. I have to press Play 3-4 times (sometimes) to get the machine to start rolling. The worst stress in this is during mixing. After setting levels on harmonies EXACTLY how I want them...I go to write the automation and the machine flips to TOUCH mode...loosing all of my settings. This is really maddening! Is my computer just too slow for PT 6.1? Or is this a bug in the software? Any other suggestions? Thanks! -todd amodeo
Your machine is a bit on the slow side. Using a separate hard drive for your audio files should help a lot in reducing the strain of the system searching for files.
In mixing, raise the buffer to 1024 - this also reduces a major strain. If you have samplers going, they are very resource hungry and could fill up the page file which will slow things down a lot while get interrupt requests.
I too have this problem, running a 1 GHz PIII. I think 6.1 is just a very sluggish program compared to 5.3.1, and maybe Digi didn't test it on older computers - otherwise, they would have found that problem before they released it.
cakes |
BBOD for 30 sec + after pressing play | clausiii | macOS | 3 | 10-10-2013 11:32 AM |
Is it possible to play a click without pressing play, and have it in sync.... | ALowe | macOS | 5 | 06-05-2011 04:24 PM |
Pressing Play or Record, Nothing Happens?? | Rockdog | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 01-25-2009 09:54 PM |
4-5 second lag from pressing play, to output? | WannabeSQ | Pro Tools TDM Systems (Mac) | 4 | 12-16-2005 09:59 PM |
PT MIX|24 Crashing after pressing play... | Schatzi | Pro Tools TDM Systems (Mac) | 5 | 03-24-2005 07:56 PM |
