all my track colors are the same
I imported some tracks to a session and now all my track colors stay the same in all session and all tracks
I try to change 1 track color to red. all tracks are now red. try to change 1 track to blue. all tracks are now blue. watched videos and messed with properties and pallet settings without any success . nobody has this problem. this has got to a be stupid easy fix |
Re: all my track colors are the same
It sounds like they are grouped or all selected.
1) Check the groups by unfolding the left pane with a little arrow in bottom left of Edit Window. 2) Check that only one track is selected (yes, it is a little cumbersome) by holding Command on Mac and CTRL on Windows then clicking a track name to de-select one track. THEN you can single left click that de-selected track to only select THAT one. You'll notice the highlight disappear from the rest of the tracks if this was the issue. THEN, the colors should apply to only the selected track.
___ >> me: nednednerB // ||main gig: editing audio voiceovers & testing software | 2nd gig: music software tutoring | hobby: electronic music // ||software: Sonoma 14.2 | PT Studio 2023.12 | Ableton Live 11 | iZotope RX, Ozone, Neutron | Arturia Pigments | Auto-Tune | Dubler2 // ||system: iMac (Retina 5K, 27", 2020) 10-Core-i9 | 128GB-DDR4 | 5700-XT-16GB | OWC Thunderbolt Hub and Thunderbolt 3 Dock // ||devices: RME Babyface Pro FS | Focusrite Clarett 2Pre | some AT mics | SM58 | Ableton Push 2 | Sennheiser HD 600 HP // Onkyo TX-8220 SR ||automation: SoundFlow | Stream Deck+ | Keyboard Maestro | SteerMouse | MacOS Shortcuts // |
I have done this several times and it always reverts back to Group 1 with all tracks in it and all tracks highlighted. then group 2 with all tracks in and highlighted. etc
Im sitting at around 40 plus hrs sitting in front of this computer with problem after problem with this DAW. I had PT 9 on widows 7 without a hitch and the upgrade and its been a complete energy suck |
Im Hoping Someone can help me here
Its Not Just the color as the problem All Tracks are Highlighted at all times, So they are Grouped for some reason Have not been able to ungroup all tracks they all will be in the grouping section in the group page as; say Group 1 program will not let me pull all the tracks out. Cant move on without leaving 1 track in Group 1 after making a phantom useless group 1 all tracks are still highlighted and grouped going back to Group page, all tracks are in the grouping section as Group 2 now. I can pull all tracks out of Group 2 but once again cannot move on without leaving a track in Group 2 making another phantom useless group 2 But all tracks are still highlighted and now in the Grouping section as Group 3. Ive searched groups, Ive searched Properties for a clue. Another thing In the Groups page that may be important. When all the tracks are out of the Groups section and i highlight one track to transfer to the Group, All Tracks move to the Group side I presently have 3 Sessions with this issue all starting when I Imported Tracks into a session that is just a session to practice my drums too All tracks are highlighted all the time. So really color coding the tracks is the least of my problems here Last edited by dirtyktm; 02-22-2023 at 03:17 PM. Reason: more info |
Can you post some images of the highlights, selections of tracks, and the groups list in the bottom left, and the contents of any groups?
Also, go here: https://duc.avid.com/showthread.php?t=300050 Follow the troubleshooting steps. Your problems maybe shouldn't be happening, and maybe the update or compatibility is an issue. Maybe you're on a bad PT version for your system. Because you have to provide such info about your setup to get proper help, I request you go to the link I posted above "Help Us Help You" at top of page in forum header. Do what is suggested, then come back with system details and pictures and we'll have clearer description.
https://duc.avid.com/attachment.php?...1&d=1677210524
if this shows up its a pic of the left side of Edit Window All tracks are Highlighted in tracks panel and on the Edit with Tracks are all in white Highlight mode. Below Group one is highlighted but it only contains 1 Click track https://duc.avid.com/attachment.php?...1&d=1677211150 This pic is of Group 2 automatically formed after making Group 1 only the click Sanda Hardware analysis Computer Model : EVGA E682 1.2.1 Chassis : EVGA Desktop Mainboard : EVGA E682 BIOS : AMI (OEM) 4.6.5 10/08/2013 Intel Management Engine (ME) : 8.0.10.1464 System Memory Total Memory : 16GB DDR3 Processor : Intel(R) Core(TM) i7-3770 CPU @ 3.40GHz (4C 8T 3.89GHz, 3.9GHz IMC, 4x 256kB L2, 8MB L3) Socket/Slot : FC LGA1155 Chipset Memory Controller : EVGA Core3 (Ivy Bridge) DRAM Controller 100MHz, 2x 8GB DDR3 1.33GHz 128-bit Memory Module(s) Memory Module : Kingston/SK Hynix KHX1600C9D34GX 4GB DIMM DDR3 2Rx8 PC3-12800U DDR3-1600 XMP (9-9-9-25 4-34-10-5) Memory Module : Kingston/SK Hynix KHX1600C9D34GX 4GB DIMM DDR3 1Rx8 PC3-12800U DDR3-1676 XMP (11-11-11-29 5-40-13-6) Memory Module : Kingston/SK Hynix KHX1600C9D34GX 4GB DIMM DDR3 2Rx8 PC3-12800U DDR3-1600 XMP (9-9-9-25 4-34-10-5) Memory Module : Kingston/SK Hynix KHX1600C9D34GX 4GB DIMM DDR3 1Rx8 PC3-12800U DDR3-1676 XMP (11-11-11-29 5-40-13-6) Video System Monitor/Panel : ACI ASUS VS228 (1920x1080, 21.7") Monitor/Panel : AOC International 2330V (1920x1080, 21.5") Video Adapter : NVIDIA GeForce GT 730 (96S 2C SM5.5 1.4GHz, 4GB 1.4GHz, PCIe 2.0 x16) Video Adapter : NVIDIA GeForce GT 730 (96S 2C SM5.5 1.4GHz, 4GB 1.4GHz, PCIe 2.0 x16) Graphics Processor D3D 11 : NVIDIA GeForce GT 730 (96S 2C SM11.5 1.4GHz, 4GB 1.4GHz) OpenGL : NVIDIA Corporation GeForce GT 730/PCIe/SSE2 (4GB) OpenGL : NVIDIA Corporation GeForce GT 730/PCIe/SSE2 (4GB) Storage Devices Disk : WDC WDBNCE2500PNC (250GB, SATA300/600, 2.5", SSD) Disk : WDC WDBNCE0020PNC (2TB, SATA300/600, 2.5", SSD) Optical : TSSTcorp CDDVDW SH-S203D (SATA150, DVD+-RW, CD-RW) Logical Storage Devices System Reserved : 579MB (NTFS, 4kB) @ WDC WDBNCE2500PNC (250GB, SATA300/600, 2.5", SSD) New Volume (D:) : 2TB (NTFS, 4kB) @ WDC WDBNCE0020PNC (2TB, SATA300/600, 2.5", SSD) Hard Disk (C:) : 232GB (NTFS, 4kB) @ WDC WDBNCE2500PNC (250GB, SATA300/600, 2.5", SSD) Optical Drive (E:) : N/A @ TSSTcorp CDDVDW SH-S203D (SATA150, DVD+-RW, CD-RW) Storage System Storage Pool : Primordial (2TB) Peripherals LPC Hub Controller : EVGA Cougar Point LPC Controller Audio Device : EVGA Cougar Point High Definition Audio Controller Audio Codec : 32768 0000 Audio Codec : Realtek Semi High Definition Audio Audio Codec : 32768 0000 Audio Device : EVGA GF108 High Definition Audio Controller Audio Codec : nVidia 0014 Audio Codec : nVidia 0014 Audio Codec : nVidia 0014 Disk Controller : EVGA Cougar Point 6 port SATA AHCI Controller Disk Controller : Marvell 88SE6111/6121 1/2 port SATA II + 1 port PATA Controller USB Controller : EVGA Cougar Point USB Enhanced Host Controller #2 USB Controller : EVGA Cougar Point USB Enhanced Host Controller #1 USB Controller : Intelitek ASMedia XHCI Controller SMBus/i2c Controller : Intel ICH SMBus Biometrics Voice : Analog NUI Voice Virtual Sensor (Voice) Network Services Network Adapter : Marvell Yukon 88E8057 Family PCI-E Gigabit Ethernet Controller (Ethernet, 1Gbps) Operating System Windows System : Microsoft Windows 10 Professional 10.0.19045 Platform Compliance : x64 |
The not being able to un group is the issue Have tried holding down (I think the Alt key on Windows) (option key on mac) and click the track name Should toggle highlight off and on for all tracks If that does not work I am guessing something in the imported tracks was corrupted and is now a PT preference . You say you have three sessions with the same issue ? But do they have the imported tracks also ? Have you tried making a new blank session from scratch ? and see if the tracks are then not grouped ? Have you tried "Trashing Preferences" goggle trashing preferences in pro tools and you likely have the Sweetwater page come up just oprn it an follow the instructions for trashing preference
System : Studio - Avid Carbon interface , PT Ultimate 2023.12 Mid 2020 (intel) iMac 27" Ventura 13.2 .1 Mobile - 2021 14 " MBP M1 Pro PT Ultimate 2023.12.1 Ventura 13.2.1 Enjoy the Journey.... Kev... |
It's Ctrl+Click on the Track Name for Wiindows.
The OP probably has Link Track And Edit Selection turned on. From the Reference Manual: "Selecting Tracks when Making Edit Selections" Pro Tools lets you link Track selection with Edit selections. When Track and Edit selections are linked, you can make a selection within a track or across multiple tracks for editing and each associated track is selected (track names automatically highlight). To link Track and Edit selections: Select Options > Link Track and Edit Selection. Press Shift+T to toggle Link Track and Edit Selection on and off. And there's an Icon to toggle under the Smart Tool.
Ah ok Control -click on Windows
Bingo !! ( link Track and Edit selections: Select Options > Link Track and Edit Selection.)
Gotta say I don't understand the concept at all Says Link the Track and Edit and in practice I'm Unlinking them but that did the trick. I can individually highlight tracks and all tracks are not in a Group format now everything doesn't have to be off lime green but I do love the color. I thought it was some major malfunction but its all a lack of knowledge thanks for everyone's impute one more question - how do you guys get that line at the bottom of your post with your system on it Last edited by dirtyktm; 02-25-2023 at 11:20 AM. Reason: more info |
Track Colors | chrismeraz | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 02-22-2015 10:13 PM |
Track colors with 7.4... | pguy | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 09-16-2008 08:04 AM |
Track Colors? | dvuckovic | Pro Tools TDM Systems (Mac) | 2 | 01-08-2008 07:33 PM |
Track colors in 7.4 | Dr Dave | Pro Tools M-Powered (Win) | 3 | 01-01-2008 04:39 PM |
Track colors | R1ch | Pro Tools M-Powered (Win) | 1 | 11-07-2007 06:05 PM |
