So, I can't figure out if I'm a dummy or not. When I'm mixing if I want to blend a, say, compressor on my drums and send to it from an aux I have latency no matter what is going on with ADC. What am I missing here?
Any less info, you could give?
For all I know your running PT7.4 on a G5 Mac with an DIGI01 as your interface.... Then again you could be running PT 12 on a trashcan pro using native soundcard....point is I just don't know Even though you posted in PT11 forum
Sorry. I'm running PT 11. I've tried this on all of my rigs. I have about 5 different rigs all towers of various variety.
Isn't adc defeated if your running in LLM?
All plugs on the aux's or only just a few plugs causing issues
Any plug I use on the a
Any plug I use on the aux does it.
How do you route signal to the aux? All ADC numbers in the green, besides one orange? Can you post a screenshot of the mix window that shows routing and ADC numbers clearly?
Sorry Amyerson I was watching the studio one live cast for the release of the new version
Standard way. Create a buss, Create a send, create an Aux track, send to the Aux track, try to mix in the aux Track, results in latency/combing. It actually occurs whether or not I have a plugin on the Aux track which leads me to believe that ADC doesn't work on aux returns properly.
LLM is on or off? Adc is on or off? (You can turn it off and on a per channel basis)
Delay comp is set to? Short Medium or Long?
Auxes vs Tracks In Input | Mike Caffrey | Pro Tools 10 | 3 | 09-19-2012 10:16 AM |
monitor auxes | rudepunk | VENUE Live Sound Systems | 2 | 04-19-2012 10:44 AM |
Sending to Auxes from Groups | markys | VENUE Live Sound Systems | 2 | 12-13-2007 06:23 AM |
how many auxes and inserts ? | nukmusic | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 07-08-2005 05:14 PM |
Distorted Sound on Auxes | Dr. J | Tips & Tricks | 1 | 10-04-2001 10:59 AM |
