PT 8.0 key features
So with all this talk about possible new PT hardware, TDM versus CPU power etc. What should a new form of HD feature to justify the current pricerange?
It's obvious that the gap between HD and LE is closing, so I'm not talking about features that would improve the current workflow, but radical changes to hard and software, that would open up new possibilities. |
The most radical change in PT would be sequence-handling, bins and network capabilities. PT is still the most linear of all non-linear edit systems. This needs to change!
I have no idea what "new possibilities" new hardware could bring. An output is an output is an output. An input is an input... |
A Digi blessed Madi I/O box would be nice for those of us with digital consoles with Madi I/O.
Buddy |
I record stems back into my Pro Tools. If Digi would have a Madi solution, I'd buy another system to record mix stems. Multiple 192 interfaces just to go between machines is silly.
Peter, consider this your lucky day then.... (or maybe you've seen this)
MADI For Pro Tools And it's cheaper than PT stuff, and works like a charm! |
* Wow, you're not allowed to post "+1's" anymore? I got an error message that said my post must be at least 10 characters. What if someone asks a question that only requires a short answer like a keyboard shortcut? Weird.
Pascal Garneau | IMDb |
Oh, and I have a few requests for PT 8.0:
1. Multiple sessions or sequences (like Frank said). 2. Bins (nahh...that would leave us nothing to hope for) 3. Audiosuite with handles 4. Multiple Audiosuite undo history (à la Nuendo) 5. Clip-based gain (à la Nuendo) 6. Waveforms that indicate relative volume, so when you raise the volume of the clip, the waveform size increases (à la Nuendo) 7. Waveforms that are visible at low amplitude (i.e. not little pixelated chunks or completely invisible) 8. Waveforms that redraw automatically after using the pencil tool 9. Macros (à la Nuendo or Quickeys) 10. The ability to somehow customize the tool selector or at least lock out stupid tools like the loop trimmer 11. Ditch the Y (snap to TC) shortcut or at least allow me to lock it out before I go postal in the cutting room! 12. Fix the Spotlight functionality in the Import window (it is currently defective). Enter a search item, the add/ copy buttons go gray. Stop the search, the search results disappear. Yay! 13. Fix the "deleting automation deletes regions when selecting across multiple tracks with mixed automation playlists or MIDI/instrument tracks" bug or "feature" or whatever 14. Revamp the auto-fade window and bring it into the 21st century or combine it with the Fade Preferences i.e. let me set the length and type of fade in preferences rather than the weird auto-fade window 15. Add track colors to Import Session Data (ISD) 16. In the ISD window, the ability to import from a selected timecode range 17. In the ISD window, fix the "some/all" checklist debacle so I don't have to open and close it 10 times 18. Fix the "overlay" ISD function so that it does not affect automation earlier on the timeline i.e. allow me to match tracks, import and overlay from a previous version, offset by one hour, and not have it blow away automation that existed in the first hour 19. Export selected tracks as new session (link, copy, or consolidate media) à la the OMF export menu item 20. Fix region groups 20a. Automatically store region groups in the Region Groups folder without having to Export them from the hidden Regions List menu 20b. Retain volume and pan automation when exported/ imported 20c. Fix the fade region group over fades in regions bug 20d. Maybe a preference that region group gets named from copying the first region instead of the track name 20e. Probably more I can't think of right now 21. Updated D-Verb (2.0 or D-Verb III or whatever). A stock reverb that sounds better than my 80s Quadraverb 21. Track/region colors that are easier on the eyes. Kill the neon pink, yellow, and green OK. That's enough from me. Oh, and don't tell to "switch to Nuendo" (I'm looking at you, Henchman). I don't want to switch (at least not until the industry does).
... please make it just as rock solid as it used to be for years. lots of single disappointments since PT 7 here. basic things like all over performance has gone much worser. sometimes pro tools crashes if i set some markers or do a "save as"... the longer i´m working on one single session (without making it sificnicant bigger) the slower PT seems to get. also the performance - slow - down whilst instantiating some (rather one VI) VIs - it´s a joke... at the moment the price stands in no relation to what i get out of pro tools 7 and above...
i don´t wanna learn nuendo or logic... i don´t like em. so - please guys - come up with something... just one system that runs without tweak- and work-arounds... thnx.
G. Rasek - recording engineer - www.overdub.at - european VO talents via source-connect - PTHD |
PT 9 New Features???? | edadema | Pro Tools TDM Systems (Mac) | 38 | 11-05-2010 03:24 PM |
Features | grebarius | Pro Tools M-Powered (Win) | 0 | 05-24-2008 12:02 AM |
PT 6.9 -Anyone know what the new features will be? | Imagine | Pro Tools TDM Systems (Mac) | 1 | 04-12-2005 06:00 AM |
New features in LE? | Dopamine | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 04-01-2004 08:53 AM |
Are there any new features in 6.2.2? | Wyn | Pro Tools TDM Systems (Mac) | 1 | 11-21-2003 05:23 AM |
