protools 7 update questions
have protools 6.7 does the update to 7 require that a previous version o protools be installed?
ie: must i have 6.9? installed i realise that i need panther installed |
Re: protools 7 update questions
Actually you need Tiger (10.4), Panther is 10.3 which will not work with PT7. Currently Digi does not support 10.4.4 or 10.4.5, so you should stick with 10.4.3 until either of those others is approved (if ever).
You do not need a previous version of PT installed to install PT7. |
thanks for info i knew it was 10.4 that i needed dehh
so i can get the upgrade from 6.7 and do not need 6.9 installed?? |
As I said,
You do not need a previous version of PT installed to install PT7. Thought it was pretty clear. |
midi questions concerning pt10hd update | matt_the_manic | macOS | 0 | 11-08-2011 11:13 AM |
10.4.9 COMBO Update Questions....... | mickdoo22 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 9 | 06-14-2007 11:51 AM |
2 Questions Sampletank 2.1 update / advice on EQ.. | ProperTonez | General Discussion | 0 | 11-19-2006 04:29 AM |
update questions | dadoffive | Pro Tools TDM Systems (Mac) | 0 | 02-14-2005 08:02 PM |
New computer ... plug-in update questions | jepmus | Pro Tools TDM Systems (Mac) | 2 | 04-29-2004 07:07 AM |
