Meter won't Budge - despite protests
the meter on my audio tracks stays in the yellow zone and can't record anything through direct input!? It worked yesterday, does anyone know why this may be happening?
even if nothing is pluged into my mbox, the second I record enable the track the meter jumps to yellow. I've tried creating new sessions and restarting pro tools, but no luck. The only thing that changed since yesterday is I added BFD lite as a plugin, which I just removed from the plugin folder in pro tools. That didn't work either. Any help? |
Re: Meter won't Budge - despite protests
Sounds like a possible feedback loop of some sort? Double check your signal flow...
Hey,
I had that same issue and I was using BFD lite alot right before it happened - all I did was shut it down and unplug everything, and shut down the mac... got some coffee and started everything back up again. New session, new template... should work fine after... good luck!
Edit Value MBP 2.66ghz 4g Ram MBox2 PT8.0.3pr |
shut down took a break (minus the coffee though), still same issue - anything else you did? (maybe I should try some coffee:)
Macbook Pro 13inch 2.53 GHz OS X 10.6 4 Gig Ram, Mbox 2 USB PT LE 8.0.3 USB interface Midisport Uno with Yamaha Clavinova |
My nudge won't budge | dBHEAD | Pro Tools TDM Systems (Mac) | 10 | 04-18-2020 03:20 PM |
why external vu meter/ plug-in vu meter differ? | sjtae | macOS | 8 | 06-06-2012 05:50 PM |
Inserts affecting send meter but not channel meter? | Kbrinson85 | Windows | 1 | 05-01-2012 07:00 AM |
Problems with RBass (sliders wont budge) | ChiDuly | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 07-20-2009 07:38 PM |
Protools makes protests when rewire Acid 5 Pro | elias40 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 05-18-2005 11:44 AM |
