Old 07-26-2015, 08:16 AM
aperez's Avatar
aperez aperez is offline
Default Offline bounce not printing Aux sends [resolved]
I have a set of Dialogue tracks and a set of FX tracks routed each to a separate Aux track (DX Bus and FX Bus). I use these buses to send audio to another set of Aux tracks with Reverb inserts, allowing me to apply reverb on all the tracks of a given category when needed. The DX Bus, FX Bus and Reverb Buses are all routed to the Main Stereo Out.
Everything plays fine BUT when I do an Offline bounce, any reverb that was applied by sending material through the DX or FX buses, disappears from the mix. This doesn't happen when bouncing real-time. However, any reverb applied individually to a single audio track by sending it to the Aux Reverb buses directly does make it to the mix.
Not sure what's causing this but I fear there is a problem with my routing that shows up when bouncing offline. If anyone has any ideas on this, i'd love to hear them.
Many thanks, Angel
Old 07-26-2015, 09:04 AM
Drew Mazurek's Avatar
Default Re: Offline bounce not printing Aux sends
Post the session without audio.
And I am assuming the Reverbs are plugins, not hardware inserts?
www.drewmazurek.com
Old 07-26-2015, 10:26 AM
aperez's Avatar
Hi Drew, yes the reverbs are plugins. Here is the stripped out session: https://www.dropbox.com/s/n02mn0ah5k...20DUC.ptx?dl=0
Thanks
Old 07-27-2015, 08:57 AM
One thing to check, make certain the outputs of the AUX tracks are actually feeding your desired OUTPUT, and not a bus with the same name. You are likely scratching your head at this suggestion, but this exact scenario has bit me twice in the last 3 months. ever since PT9 was released, the buses have had a mind of their own to some degree
Old 07-27-2015, 09:32 AM
Thanks
Worked fine here. Have you tried a different verb? I didn't have Altiverb so I used another and it worked both ways.
Also, are you sure you're selecting the "physical output" that you're monitoring from?
www.drewmazurek.com
Old 07-27-2015, 08:53 PM
gives's Avatar
gives gives is offline
Hey Drew, Altiverb does work in offline for me with no problems. BTW.. There is a NEW update for Altiverb posted in the last few days to Altiverb 7.2.6 ..
G
Gregory Ives, Composer/Sound Designer/Musician
http://www.gregives.com
https://pro-labs.imdb.com/name/nm1170521/?ref_=sch_int
Protools 2021.7 Ultimate HD Native Thunderbolt Avid MTRX. DAD MOM,Mac Pro 3.5GHz 6-Core Intel Xeon E5 64GB of Ram
OSX Catalina 10.15.7 Digital Performer 9.5.2, Logic Pro X 10.6.3
Old 07-28-2015, 04:47 AM
musicman691 musicman691 is online now
What version of PT was this session done in? Tried it on my PT11.3.1 vanilla and got all kinds of error messages about routing and such not available in my PT version.
Jack
QAPLA!
Old 07-28-2015, 03:27 PM
aperez's Avatar
Thanks for testing it your side Drew.
I've tried changing reverbs and Bouncing to all possible outputs made available but still no luck. Which leads me to believe there's something wrong with my I/O settings - but looking there everything is pretty much the default. I've attached a few screenshots, see if anyone can spot anything dodgy.
Thanks again.
Old 07-29-2015, 01:44 AM
aperez's Avatar
I'm on PT 11.0.2.626 - downloading/installing 11.3.1 see if that helps.
Old 07-29-2015, 01:47 AM
aperez's Avatar
G
Thanks Gregory - Altiverb updated to 7.2.6 but no better.
Offline bounce crash, probably Waves-related, and offline bounce not 100% correct Skwaidu Pro Tools HDX & HD Native Systems (Mac) 3 03-23-2015 03:55 PM
Offline bounce vs. Realtime bounce significant differences Mano Pro Tools 11 13 05-29-2014 05:58 PM
offline bounce different than realtime bounce grant howarth Pro Tools 11 8 12-08-2013 09:29 PM
Bounce to disk vs. printing to track mr.armadillo Post - Surround - Video 4 06-15-2006 09:07 AM
Outboard FX not printing with the Bounce to Disk!? Animal 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 02-26-2005 09:27 AM
