Old 06-15-2006, 05:13 AM
mr.armadillo mr.armadillo is offline
Default Bounce to disk vs. printing to track
I'm using delay compensation in PT 7, and when I print the final mix to a track, everything is perfectly in place - except for the last sample, which is always zeroed. When I bounce to disk though, the first 2 samples are truncated, leaving 2 samples of zero at the end. While 2 samples are not that much and you certainly won't hear that in theatre, it's still irritating. I've also noticed that printing to track results in more accurate automation processing than bounce to disk. Are there any other differences? What do you guys use, bounce or print?
Old 06-15-2006, 05:45 AM
Wellnitz Wellnitz is offline
Default Re: Bounce to disk vs. printing to track
Hi mr. armadillo,
in most cases i prefer record to a track for 2 reasons.
First, your mix stays in the same session. From there you can export it in any format you like.
Second , if you need to make a change and that will happen constantly, you can make this very easy with destructive record on and you only allocate the area you need to change instead of bounce the hole mix.
my 2 cents
Jochen
Old 06-15-2006, 08:09 AM
ChannelZero ChannelZero is offline
how do you know this?
Old 06-15-2006, 08:46 AM
TVPostSound's Avatar
TVPostSound TVPostSound is offline
We have compared bounces to track mixes!!!!
IMDB
Old 06-15-2006, 09:07 AM
JKD99 JKD99 is offline
FWIW, I don't know why ANYONE bounces anymore, especially when you're doing post (meaning long reels, not 3-4 minute songs). Just being able to punch in on the mix makes it so much more flexible and ultimately timesaving than bouncing. The only time I use bounce is when I have to generate a stereo interleaved file for someone, and even then it's bouncing an already-created split-stereo file, not a running mix.
My 2¢
Joe Milner
Puget Sound, Inc.
Los Angeles
IMDB
Puget Sound on Facebook
HTML code is On
Mix Help - mix to track or bounce to disk? coolbro Pro Tools 9 2 09-04-2011 09:35 AM
Bounce to disk each track separately cresinteractive Pro Tools 9 5 07-06-2011 09:46 AM
Outboard FX not printing with the Bounce to Disk!? Animal 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 02-26-2005 09:27 AM
Can you bounce a MIDI track to disk? Funkmaster69 Tips & Tricks 14 03-19-2004 06:50 AM
How can I Bounce to disk a midi track? PJN Digidesign Hardware & Software 3 02-16-2002 10:19 AM
