Old 10-08-2023, 03:55 AM
roderickelms roderickelms is offline
Default Adding accel card to Pro Tools 8 HD Mac
Just looking for a little reassurance here, as it's a long time since I set up my Pro Tools 8 HD system.
I just have the standard core card with a 96 i/o interface. If I add an extra PCIe accel card, what will I gain? I currently seem to be limited to 48 tracks, and on larger sessions, I frequently get a message warning about the number of active audio/RTAS-enabled tracks.
Would someone be able to say what the benefits would be of an extra card – I don't seem able to find this information anywhere. Would this help the above issue?
Thanks for any advice.
www.masterkeyboards.co.uk
Old 10-08-2023, 05:50 AM
Default Re: Adding accel card to Pro Tools 8 HD Mac
You get more voices and more than double processing power (mixer stays on core card, second one is all available for plugins.
Bear in mind that with the card you also need that ribbon cable, which is many times missing when someone sells 2nd hand. It is hard to find.
And the ribbon card must go from core card B connector to accel card A connector. Counter-intuitive, right? They should have lapeled them IN (A) and OUT (B), but no.
Old 10-08-2023, 09:21 AM
Thank you so much for this - much appreciated. I assume that there was only ever one incarnation of this card and that a card advertised as a 'Digi accel PCI card for Pro Tools HD' would fit the bill for my Mac Pro Tools 8 HD system?
Old 10-08-2023, 09:47 AM
There were two, one for PCI (or PCI-X) systems and another for PCI-express systems. Check your computer which you need.
There were also two different extra cards for PCI (or PCI-X) systems -- original and accel. The PCI-express cards however are all accel.
Old 10-08-2023, 09:49 AM
Thank you, Janne. It's a 2007 MacPro, so PCIe. I appreciate your support with this.
Old 10-08-2023, 10:21 AM
No problem. I have had both of those (PCI maxes out at 8 and PCI-express maxes out at PT10) and still know them inside and out. Also had MIX but have begun to forget many things about it.
Old 10-08-2023, 10:24 AM
Ha – I had the Mix, too. Still have the interface, I think!
Adding another Accel card ? jackp Pro Tools TDM Systems (Mac) 8 10-28-2012 09:25 PM
Adding an Accel Card Drama Diggerthedogboy Pro Tools TDM Systems (Win) 2 11-11-2011 11:26 PM
Adding another 888/24 and Accel card. Please advise. ProTooler Pro Tools TDM Systems (Mac) 11 02-15-2011 12:07 PM
Adding another Accel card Dusan Pro Tools TDM Systems (Win) 4 02-18-2010 04:05 PM
Adding Accel Card to HD3 -Questions Ed Kish Pro Tools TDM Systems (Mac) 6 11-18-2003 01:43 PM
