Old 02-21-2006, 01:20 PM
qbert1 qbert1 is offline
Default DINR vs. Camcorder noise
Which do you think will win?
I have a friend who is archiving a video interview. The interview was good but he used the mic on top of the camcorder. I was thinking of renting DINR to eliminate this noise. Will that work or will I find I've wasted my money?
Any other suggestions are appreciated.
BK
Old 02-21-2006, 01:26 PM
MorganPost MorganPost is offline
Default Re: DINR vs. Camcorder noise
Try a notch filter/EQ or if you have access to a Cedar DNS unit, that would take care of your issue, but you should be able to make things fly with a notch EQ setting.
Old 02-21-2006, 01:39 PM
TVPostSound's Avatar
TVPostSound TVPostSound is offline
Judicious use of a notch filter, and gate. (Thats how we did it in the past!!!)
Try waves X-noise or Z-noise demo, fully functional, and good for 10 to 14 days or so.
IMDB
Old 02-21-2006, 05:19 PM
Good advice from both. I'll look into it. Any other ideas?
Old 02-22-2006, 03:53 AM
mindnoise mindnoise is offline
HI,
if you aren´t afraid of working in Classic Mode you can download sonicWorx Powerbundle from
www.prosoniq.net for FREE. (->Download->freebies + ASIO Driver) and follow the instructions to
setup.
It has a great Noise reduction capability amongst other qualities.
regs
last: PT11.3.1
Old 02-22-2006, 02:30 PM
The Dougfather The Dougfather is offline
Soundtrack Pro has the ability to take a noise print if you have a solo piece of noise and will then try and eliminate it from the audio. Adobe Audition/Cool Edit Pro (PC) had a similar feature. With these pieces of software there is an offset of audio degredation vs. noise reduction, the more you tend to use noise reduction filters the worse the sound gets, it just a case of reaching a happy medium.
Regards
Mike
iMac i5 2.8GHz, Macbook Pro 2.4GHz, Pro Tools 10/11, MOTU 828mk2, Presonus Digimax FS, Presonus Firestudio Project, TC Konnekt 24D
iCON Photography
DINR LE Broadband Noise Reduction Torchlight Tips & Tricks 8 10-10-2006 09:54 AM
no noise vs dinr Cawbaby Pro Tools TDM Systems (Mac) 0 02-23-2005 04:18 PM
DINR noise reduction lightning ad Post - Surround - Video 3 12-01-2004 07:51 PM
Can DINR safely remove mic noise azure sky Tips & Tricks 1 03-30-2001 09:54 PM
DINR vs No-Noise vs Cedar sound kuch General Discussion 0 06-25-1999 08:16 PM
