S1 randomly writing PAN automation
Just installed an s1 on my work's PT Ultimate system (2018.10) and when I hit play, a track will randomly start writing pan automation. Any idea why? I started with Eucon 20.1 and then downgraded to Eucontrol 19.12. Happens on both versions.
Upgrading the PT software to the lastest version is a bit of a challenge since it's a corporate system, but I guess these days, it should be easier to get approval. |
Re: S1 randomly writing PAN automation
I had this happen when one of my knobs died - you could see the oled display fluttering around a little on the numbers even when untouched. It ended up needing to be sent in.
Yes, I've seen the display slightly flutter. This is a brand new S1. Not even 5 days old. Ugh, I hope that's not the case.
I just upgraded to 2019.10 and Eucon 19.12.1 and it's still happening. |
Yes, thank you! This is the same problem, however I WAS able to get a replacement unit from my dealer today and the EXACT problem is happening on the second unit as well. Any other ideas??
I trashed PT prefs and that did nothing. I've upgraded to latest Eucon 20.1.0.50 and problem is still there.
You need to contact Avid Support to get a replacement not your dealer.
I've been having the same issue on my Avid s1 since march
Windows 10 Pro Tools HD v.12.5 EuControl v. 20.5.0.149 Avid s1 Firmware v. 20.5.5.0
Contact AVID ASAP. They sent my replacement very quick.
Automation not writing | Jenre | Windows | 7 | 07-02-2014 10:04 AM |
Automation writing on it's own | cananball | Post - Surround - Video | 4 | 06-28-2014 11:36 AM |
Writing Wah automation from GR5 | tha]-[acksaw | General Discussion | 1 | 02-14-2014 11:44 AM |
Writing automation? | danander11 | Tips & Tricks | 2 | 11-22-2009 08:24 PM |
automation issues (re-writing automation when it shouldn't) | revere | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 02-13-2008 02:41 PM |
