Old 09-09-2006, 08:32 PM
kimmie kimmie is offline
Default Grid/Groove quantize: assertion failure
Hi there,
I'm trying to use Grid/Groove quantize, but the dialogue doesn't let me do anything. First I extract a groove template to the clipboard. Then I close down beat detective, make a new selection and open the Grid/Groove quantize dialogue, but:
  • The "Apply" button is greyed out
  • The entire "what to quantize" group is greyed out
  • The big button in the "quantize grid" section shows "Groove Clipboard".
  • If I click on the "Groove Clipboard" button, I get "Assertion in \code\aztec_Lomax\AlturaPorts\NewFileLibs\Sys[..rest is cut off] line 85". I've seen one other post (see here) which looks like the same problem, that leads me to believe that the assertion happens in Sys_FileLoc.cpp line 85
  • If I click on "Show Comments" the the only text I see is "Comments:"; the comments I typed when I extracted the template don't appear.
In short, Grid/Groove quantize is out to lunch.
This happens with ALL tracks in the session. If I create new tracks and regions or extract a new groove template, I still get the same error. I can delete all the tracks in the session and start again, same error.
However, Midi real time properties works; I can extract groove templates and save them to files and apply them from here.
Other sessions work fine, it only seems to be this session that has the problem. If I export all the midi from the problem session and import it to a new one, everything is fine.
I'm using PTLE7.1cs9. I had the same problem under cs7.
The bogus session is available here if anybody else wants to check it out.
Assertion Errors Elastic Audio Quantize to Extracted Groove PookaStew macOS 0 12-01-2012 10:29 AM
EA Groove Quantize Assertion Error guitar486 macOS 6 01-21-2012 01:16 PM
Groove/Quantize Assertion error robersl 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 09-14-2007 09:55 AM
How do I UNDO quantize or groove quantize in PT6.9 Asymmetric 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 11-24-2005 07:04 PM
LE and Groove Quantize babyalex 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 05-04-2003 02:22 PM
