Go Back   Avid Pro Audio Community > Pro Tools Software > Pro Tools | First Discussion
Old 01-26-2022, 05:00 PM
Juan Carlos Palacios Juan Carlos Palacios is offline
Default Pro Tools First does not load
ProTools First worked perfectly until a week ago when it didn't start, it crashed when reading the plugins.
I have reinstalled the software 2 times and it doesn't work.
Please I need help I would be very grateful.
Thanks
File Type: png Captura de pantalla 2022-01-24 a la(s) 13.14.59.png (31.2 KB, 0 views)
Old 01-28-2022, 02:09 AM
junkgear's Avatar
junkgear junkgear is offline
Default Re: Pro Tools First does not load
Are you using the plugins that came with Pro Tools First only or have you installed additional plugins?
You can try removing the plugins from the plugin folder one by one to see which is hanging Pro Tools. Do not delete them, just move them to a different folder on your system and restart PT.
Will
System Details
Old 02-09-2022, 04:42 AM
I already did, and unfortunately it still doesn't work.
Checking the avid page, it says that ProToolsFirst is discontinued.
Ok, but what about my projects?
How can I do to export them to wav and reuse them?
Thanks
Old 02-09-2022, 10:05 AM
jeffro's Avatar
jeffro jeffro is offline
Your signature lists macOS Sierra which wasn't qualified for v2021.6 (though you said it was working previously). I'd suggest trashing InstalledAAXPlugIns which will get recreated on launch. Find this in: /Users/*username*/Library/Preferences/Avid/Pro Tools First
Pro Tools will not load Keniko Pro Tools 2020 2 11-02-2020 11:43 AM
Pro Tools 11 Won't Load Verses Windows 2 08-26-2017 09:26 AM
Pro Tools could not load the following.. daverose Pro Tools 10 8 09-21-2015 01:39 PM
Pro Tools 10 not load plugins,freezing load.HELP javierboz Windows 2 11-08-2012 04:25 AM
Pro Tools 8 LE won't load SoundQuarters 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 11-28-2010 04:07 AM
