Old 12-11-2011, 07:16 AM
natural natural is offline
Default My xmas present...but it don't work
Brought a roland v drum
Plugged the midi into my 002
See the midi input light go on
Set up aux and a midi channel for ez drummer
hear the drums sounds with the mouse on the interface
Cannot get the v drums to trigger the ezdrums
Have a command 8 that works fine
thanks for any help
Old 12-11-2011, 10:57 AM
cwsand's Avatar
cwsand cwsand is offline
Default Re: My xmas present...but it don't work
You should use a MIDI track and Instrument track. Put EZ Drummer on the instrument track. Set your MIDI track to the proper MIDI channel, and set the output to the EZ Drummer plugin. Other things to check - make sure the 002 is listed under MIDI devices in Pro Tools. Try rebooting the computer.
Help Us Help You
Chris
Focusrite Liquid Saffire 56
FocusritePro 40 (2)
TCE Studio Konnekt 48
Rascal Audio Tonebuss 24
UAD-2 Octo Core PCIe
macOS Catalina 10.15.7
Pro Tools HD 2021.12
Old 12-11-2011, 03:15 PM
Thanks for the info.....
here is where the voodoo is, need to be more specific
Old 12-11-2011, 06:02 PM
Actually, you only need a stereo instrument track(midi is part of it already). Go to Setup>Midi>Midi Studio and create an instrument there(this is a midi instrument, not a VI). Setting the brand and model are not so important(so don't panic if you can't find the exact model of the Roland kit, just pick any TD kit). Just make sure you assign the midi IO and set for midi channel 10(that's the default channel for drums and percussion). Click OK and exit that window. In your session, create a stereo instrument track and put it into record ready. The Roland kit should now play the drum sounds(this is how it works here anyway). By default, all midi/instrument tracks will receive any midi, on any channel and from any recognized source. Its gets trickier later on when you want to use the Roland kit at the same time as a keyboard
BTW, the ezdrummer plugin should always go in the very top slot(slot A).
Old 12-11-2011, 07:29 PM
First of all thanks for getting me a step closer...
I have added a new device but the little arrow/wires do not seem to connect to the 002 icon...
My keyboard is connected to #3 on the 002 icon.
Above info applies to transmits and receives properties?
thanks again
Old 12-11-2011, 07:46 PM
Update, got the wires connected but not sure the ports on the 002 icon
Still messing around with many variables and no sound yet.
saw your web site nice studio and tunes...
Old 12-11-2011, 10:32 PM
cwsand's Avatar
True, that usually works, but I have used some VI's where I've had to create the MIDI track and Instrument track in order to get them to work. I included that step in case it was one of those situations...
Help Us Help You
Chris
FocusritePro 40 (2)
Old 12-11-2011, 11:34 PM
Stratomaster Stratomaster is offline
I've been burned by the "midi through" being unchecked, could be that.
[IMG] code is Off
Xmas present from family - ideas? Currently have Mbox Pro 2nd generation gbross Windows 5 12-04-2011 09:51 AM
Video Window says "No Movie Present" when a video is present SoundBedouin Pro Tools M-Powered (Win) 6 03-10-2011 08:37 AM
please help-xmas present - son-le freezing startup bbq75 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 12-26-2004 05:07 PM
Mackie's Xmas present Compression Records Tips & Tricks 0 12-22-2000 07:30 PM
PT 5 TDM/LE work w/ OS X partition present? jweisbin Pro Tools TDM Systems (Mac) 3 09-20-2000 01:40 AM
